Question about Whirlpool GS6NVEXSL Side by Side Refrigerator
I have Whirlpool Gold Side by Side Refrigerator/Freezer (Model #gs6nvexsl. The ice is generated fine, but will not dispense. The dispenser itself does not make a sound (auger does) when I depress the button for ice. I think (correct me if I am wrong) I have isolated the problem to the ice dispensing motor (PN# AP4410923). Do you think this is truly my problem and if so, how do I replace the motor?
2 Suggested Answers
SOURCE: Whirlpool Gold Side By Side Ice Dispenser Problems
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit www.FixMyFridge.net for refrigerator service or to ask general refrigerator questions.
Posted on Mar 19, 2010
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Dec 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refigerator won't engage ice dispenser.
Could be that the auger in the ice bucket is obstructed or broken, or the auger motor is bad.
Nov 02, 2017 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool gs6nvexsl
behind the kick plate is a repair tech sheet for the ice maker.
Feb 21, 2008 | Whirlpool ED5FTGX Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NVEXSL Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
