Question about HP Deskjet F4210 All-In-One InkJet Printer
HP DeskJet F4210 printer. Tricolour light flashing. Checked HP manual for info. Checked door, seating, even replaced colour cartridge, still flashing. Other causes?
    Sniper:
  • 66 Answers
Try with another tri color cartridge, if that works fine, then the previous cartridge was faulty and if that does not work, printer is faulty, so, service the printer ..
Posted on Dec 11, 2009
SOURCE:
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
The orange light flashes even though I have changed the colour cartridge, The printer will not print
change the catr insecting unit and the cable together for it to work well. that the problem
May 23, 2009 | HP DeskJet 940c InkJet Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Cartridge alignment failed on a C5280 HP printer
I had the same problem after changing the black cartridge. After trying everything i found online to fix this fault and replacing the new black cartridge again, i replaced the tricolour cartridge even that it had a quarter ink left! This solved the problem, I think the colour was abit weak for the printer to check alignment.
Try it, it worked for me and good luck
Dec 07, 2008 | HP Office Equipment & Supplies
HP PSC All-in-One
hold down the power button on powerup, try this in conjunction with several other buttons I"m not sure which but theres a reset or consult manual.
Aug 12, 2008 | HP PSC 1210v All-In-One InkJet Printer
Hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Jun 26, 2008 | Office Equipment & Supplies
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
HP Deskjet F4210 All-In-One InkJet Printer Logo
430 people viewed this question
Clive
Clive
Thomas F. Schneider
