Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Strong chemical smell coming from fridge. almost
Strong chemical smell coming from fridge. almost like a permanent marker, fridge is still working. smell has been going on for over a week.
  • 25 Answers
SOURCE: Chemical smell from refridgerator
Most refrigerator use R22 freon and this stuf does not smell very much. Maybe there is some milk or blood comming from a leakink pack, that entered between interior panel joints. Try placing an opened Harm & Hammer soda box; this could catch the odors. If after a week or so, this did not resolved this issue, I one had to replace some mineral wool (insulation) that as been contaminated with rotten food.
Posted on Nov 24, 2007
xMadx
  • 64 Answers
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Posted on Feb 04, 2008
bestdarngood
  • 3037 Answers
SOURCE: chemical odor...
try putting crumpled newspaper in it daily to get rid of the smell, the coolant if leaking should not cause any horrible smell, Freon they use today has very little smell to it. Frost free units have heaters and fans in them to keep them frost free. It could be that a fan quit and the heater overheated something around it."
Let me know if this helps, good luck
Posted on Mar 29, 2008
22yooper
  • 828 Answers
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
All items stored in the refrigerator and freezer should be stored in sealed packaging. Frost free refrigerator operate with a very low humidity and will pick up odors from products. Somewhat of an ozone smell will be in some frozen foods. This is a normal condition. Deodorizing packs are available on the market to absorb odors. Baking soda does the job in most cases.
Posted on May 31, 2008
mark_37388
  • 100 Answers
SOURCE: whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Posted on Mar 27, 2009
Why does my fridge and freezer have a chemical smell?
What might cause a chemical smell coming from a ... - Ask.com
www.ask.com > Home & Garden > Appliances > Refrigerators & Freezers
Coolant leaks and the use of chemical based cleaners are common causes of achemical smell in the refrigerator. Immediate action is necessary if the cause of
Jul 27, 2015 | Frigidaire Refrigerators
Chemical odor in the refrigerator
The fridge working normally? Check the plastic around the bulb, do you see some coloring, if yes then the bulb in on all the time.
Mar 24, 2013 | Refrigerators
New Refrigerator Smell
heck for protective packing for shipment. check user manual for any packing that may need removal
Apr 02, 2017 | Summit Appliances Division Refrigerators
There is a strong chemical burning smell coming from the fridge/freezer but it still seems to be working ok at the moment, the light is on and still feels cold, any ideas what this could be?
if the smell is very sweet something like peardrops, could be poystyrene packing. check for cable chaffing where it enters cabinet.replace mains cable completely. if mains cable outer cover is getting too hot it will smell as above WARNING polystyrene gives off cyanide gas over 120c/when burning do not inhale(only had 1 freezer melt in 30 years it was set on purpose)
Feb 07, 2010 | Refrigerators
About 5 days ago I noticed a strong chemical smell (like open permanent markers or nail polish remover) in my kitchen. The smell permiates the whole house, but is strongest in the kitchen area when I close...
No. The coolant cannot leak as a liquid and soak into the floor. Also, the smell of the coolant (refrigerant) does not have the acetone/ketone/laquer thinner smell that you are describing, and if someway the smell originated from the frig, the smell would without a doubt be inside the frig as well. You need to look frosome container stored in a cabinet or stored on conrete floor that has rusted or opened some way and the thinner/cleaner/solvent has leaked from such a containerwithout notice. Goodluck, Macgivor
Jan 27, 2010 | KitchenAid Superba KSCS23IN Side by Side...
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Fridge has chemical smell
The smells are being pulled in through the air intake from the fridge from the chemicals they used on the floor. As the coating cures, the odor will end. As for the damage to your food and drinks? I would assume if the food tastes like the chemicals, I would avoid eatting them if you do not like the taste )
Apr 06, 2009 | Hotpoint HSS25GFP Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
646 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
