Question about Magic Chef Refrigerators
Magic chef frig door won't close - Magic Chef Refrigerators
  • wadascream Jan 05, 2010
    I now have discovered the problem. The door liner has pulled away from the bolts. The bolts are still in place. How do I get the liner to seal to the bolts again? The liner has ripped away from the bolts so that there is a hole all the way thru to the edge. the liner is part of the whole door compartment. I do not want to replace the door.
  • Magic Chef Master
  • 17,314 Answers
What do mean when you say that it wont close? There are only three things that could cause this:
1. There is something blocking the door from the inside
2. There is an issue with the magnetic seal that is around the door.
3. There is a problem with the alignment of the door.
1. Is obviously something you checked for the only thing that you might have missed is ice and this is not likely.
2. The seals on the door are actually prone to compression and they done spring back nicely. They have test for them and that test is that if you close the door on a piece of paper and you can pull that paper out of the seal between the door and the wall then it is not good. The way to fix this is to get a blow drier. (techs use a heat gun but it gets too hot for DIYer) Put the drier on high heat and heat the seal a little at a time and pull it out away from the door as you get it hot. This expands that compression that takes place over time.
3. Some units have adjustable hinges. You can make it a left hand or right hand door. If that is the case then the hinges can be removed from the top and bottom of the frame and replaced on the other side. THe problem may lie in the loosening of the bolts or cap screws that hold the hinges in place. You can check this easily with a wrench. Last but not least the hinges could be sprung out of shape from force and you can adjust them with the same pressure that made them bend out of shape.
Posted on Dec 11, 2009
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
How to unlock majic chef wine refrigerator
Magic Chef should be able to help with this problem
Feb 26, 2013 | Magic Chef MCWC30MCG Compact Wine Cooler
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
MAGIC CHEF ELECTRIC DRYER DOESN'T WORK. WHEN I PUSH THE ON BUTTON, NOTHING HAPPENS. POWER SWITCH IS ON.
Hello dybarra_fami, first suspect is the door switch. Check the little button on the door & the switch it presses when you close the door. Merry Chrismas.
Dec 05, 2008 | Magic Chef CYE4000AWW Electric Dryer
Latch on door won't close.
THe door wasn't closed right.  When I pushed the corner closed and it was lined up correctly, it latched.
Dec 05, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Open Questions:
Refrigerators Logo
29 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
