Question about Kenmore 54701 Dehumidifier
Humidifier makes a beep when pluggged in but does not work. what could be the problem?
  • Kenmore Master
  • 8,404 Answers
Is the bucket properly in place? If not, the machine thinks the bucket is full and will not come on.
Check it out
Thanks for your interest in FixYa.com
please vote
Posted on Dec 11, 2009
I have the Kenmore 14 gallon whole house humdifier. The humidity level only goes up to 30 even though I have it set to 45. I changed the filters,cleaned the unit and tried unplugging but it did not make a...
My suggestion is to get an additional humidifier and run both. It sounds like it is at capacity. This was a cold winter and the additional heating put a large demand on the humidifiers.
Feb 27, 2014 | Kenmore 14 Gallon Humidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
New Delonghi Dehumidifier,5 gal:When units beeps that bucket is full,what are exact steps to do 1st:empty bucket, then press what button to restart?or does it restart on its own?
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
Jun 07, 2010 | DeLonghi Dehumidifiers
The humidifier makes a beep when turned on,
The water tray is probably not installed correctly. Take it out and reinsert it. It has to close a switch when it is in place.Mine at home is really touchy it has to be put in just right to work.
Nov 12, 2009 | Kenmore 54701 Dehumidifier
543515 humidifier runs but doesn't collect any water.
try checking the setting of your humidifier, if the actual humidity level matches, what is set on your unit.
Aug 01, 2009 | Kenmore 54351 Dehumidifier
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Humidifier sopped working.
I take it that the bucket is empty? I'd suggest making sure that the bucket is properly inserted back into the casing, and that none of the little actuating rods has got broken.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 07, 2008 | Kenmore Dehumidifiers
Maytag M7DH45B2A freezing problem
Is this a humidifier or dehumidifier?
Nov 15, 2007 | Maytag M7DH45B2A Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
1 yr old and Stopped working
the beep sound means that there are ac voltage in the unit but you gona need a tech there is no removal parts in that board and sound as a bad ic is there..good luck
Aug 05, 2006 | Kenmore 54701 Dehumidifier
Kenmore 54701 Dehumidifier Logo
214 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
