Question about Dell OptiPlex GX520 PC Desktop
Amber light solid. Replaced the power supply ad the cmos battery. removed the memory and reconnected. Plugged back in and I hear the fan running kind of loud (louder than before) Still solid amber light
  • 345 Answers
Most times i have seen amber light, if it is where the pwr light is on front of tower means ur mother board might be fried. check capacitors one by one and make sure none are extended or leaking. dell has had this issue before when they sent out a bad batch of capacitors. may last it job was mostly issues with this. good luck.
Posted on Dec 11, 2009
Amber light on then a while turns green but wont boot
1) Switch the system on. Can you tell me if the power button is flashing amber or a solid amber? Please also tell me if you notice any diagnostics LEDs staying lit - these are labelled 1,2,3 and 4 and are near the front headphone sockets
2) Please remove all peripherals at the back of the system and switch the system on. Does this affect the power button LED or diagnostic LEDs
3) Have you added any components to the system e.g. video cards, sound cards etc...
4) Please open the system and remove the following components:
a) Power and data cables from hard drives and optical drivesb) Any PCI/PCI-Express expansion cardsc) All memory from the systemd) The system fan
5) With the above removed, please reconnect the power cord to the back of the system and switch the system on. Please make a note of what happens with the power button LED and the diagnostic LEDs
6) If there are no changes to the power button LED or diagnostic LEDs, please remove the power cord from the back of the system and remove the following components:
a) I/O panel cableb) CMOS battery
7) With the I/O panel cable and CMOS battery removed, please connect the power cord to the back of the system. The system should automatically try to switch on. Do you hear any beeps from the system? If so, can you tell us exactly what you hear?
If you need any assistance with removing these components, please see the User Manual here: http://support.euro.dell.com/support/edocs/systems/op380/en/index.htm
Please keep us updated on how you get on!
May 21, 2014 | Dell OptiPlex 380 MT Desktop Computer...
Dell dimension2400 power light is orange and fan is on machine not working
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 27, 2013 | Dell Dimension 4600 PC Desktop
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Optiflex sx280 does not start.
Fans working? Maybe a PSU failure? Replace CMOS Battery. Reseat/replace Memory Mods. It's getting a bit old. Hard to say with a older computer thing start to go one by one. I replaced a PSU after 7 years. CMOS battery dead, replaced, Then the Sound Failed, new sound card. etc. I stripped it of useful parts and sent it out into the world.
Jan 02, 2013 | Dell OptiPlex SX280 PC Desktop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Dell dimension c521 solid amber light
When you plug in the power cord is there any lightswhatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your power supply is going bad or is bad. Sometimes the power supply has enough power to emit a light or make lights come on but not enough power to start the fans or disk drives.
Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 29, 2012 | Dell Dimension C521 PC Desktop
Solid orange light on my vostro 200
If your fans come on full blast then you have a bad motherboard. If the amber light blinks, you have a bad power supply.
Nov 26, 2009 | Dell Vostro 200 Desktop Computer
Solid amber light. No power to the system just the fan runs.
Solid amber light means the CPU is not being powered properly, that is USUALLY a bad power supply. Contact Dell and order another power supply. if that doesnt fix it, you have a bum board. (usually, you will see popped capacitors on the board if its bad). I will say, that in about 70% of these, its a bad power supply. power supplys arent cheap (unless you have a warranty of course) but they wont break the bank. a replacement is likely going to be about 40-70 dollars. I havent priced it, but you can ask dell at dell.com/chat. Good luck.
Nov 19, 2009 | Dell DimensionTM XPS 710 PC Desktop
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Dell OptiPlex GX520 PC Desktop Logo
1,894 people viewed this question
Alun Cox
