Question about 2wire (1000-000057-000) Modem
2 wire modem
When i try to use the wireless internet it asks for a password and i did not setup a password what do i do?
  • Anonymous Jun 29, 2008
    no wireless icon to click on
    Novelist:
  • 173 Answers
Look at the back of your two wire modem, you would find a 10 digit number that would be the default password, try it out, or else you need to login to your modem setup page to get the wireless settings, contact 2 wire they would help you to login and get the wireless settings
Posted on Jan 21, 2008
The first suggested solution is right. just look at the 10-digit on the bottom of your modem. that is the set of numbers which is enclosed with a parenthesis. type it as your wireless network password. if you want to customize the password, just do to the modem interface and include mdc at the end, for example, "gateway.2wire.net/mdc" using your computer browser. you will see a list of options at the left. got to local network>wireless> you will see here the list of things you can do about your wireless network including the customizing the password.hope it helps
Posted on May 06, 2008
Its not the10 digit number..its the 26 digit number..on the sticker if u turn the 2 wire modem upside down ..that the default encryption key..WEP u can also set a custom passphrase-->
#open the firmware of the modem..for eg.192.168.2.1
#click home network at the top.
#go to wireless settinfs..
#change the authentication to WPA-PSK from WEP-OPEN
#choose the "use custom passphrase" instead of "default encryption key "
#put a key (atleast 10 characters)
#click save
#try connecting..
#it will now ask for a WPA-PSK key rather than WEP eky..
#punch in the key..
#click on connect
## done..
Posted on Oct 03, 2008
How do i find my wpa2 key for my belkin router, i am trying to get my xbox live up and running and it wont go any further without it
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 10, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Internet connection frequently drops netgear wrn2000
Hi
If the Internet connection frequently drops, It could be wired or wireless.
If it is wired connection u can try the following troubleshooting steps
1) connect Modem-Router-Computer
2) Open router UI (www.routerlogin.net)
3) User name : admin , Password: password
4) on the left hand side in the blue panel select WAN setup & reduce the MTU to 1400 & click apply.
if the problem still continues upgrade the firmware of the router.
This should resolve the problem
NOW IF THE WIRELESS CONNECTION DROPS, try the following troubleshooting steps
4) on the left hand side in the blue panel select Wireless settings (under Setup)
5) SSID: (user defined)
Channnel : 11 or 6
mode : upto 54 mbps or 150 mbps
Security : WPA-PSK (TKIP)
PASSPHRASE : (user defined)
Click apply
This should resolve the problem.
Thanks
Vineet Bajaj
Sr. Tech support Engg.
NETGEAR
Jan 11, 2010 | NetGear WNR2000 Wireless Router
I never set up a password for this router but everytime i tried to conect to internet thru my laptop it asks me for a passowrd. is there anything like a universal password that i should use?
if its asking you for a wep key, you must go into the modems page and get it.
i think best way to find the modem page is goto start and in run type cmd, then type ipconfig, the default gate way is the adress to your modem page type this number with is some thing like 192.168.2.1 into your internet explorer page, this should bring you to your modem. navagate through this untill you find wireless settings and in there you will see the wireless wep key. if it ask you for a password try admin and pass admin or admin with no pass, you can google what your password is to this modem if you have a problem. hope this helps,
you do all this on the computer that is conected.
Nov 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have a WGT624 router. I have had verizon internet for about 2 months. Recently, I could not get on the internet using wireless but could when just using the modem. I have unplugged the router and then...
either you need to reconfigure the router for the wireless configuration or setup the router for PPPoE connection. if you have internet directly to the modem contact your router manufacturer if not then you need to contact your ISP and ask if you need to setup the route rwith PPPoE connection and get the user/password
Sep 07, 2009 | NetGear WGT624 Wireless Router
My laptop shows full signal but refuses to connect to the router. The wireless phone rang two days ago and knocked me offline on wireless. Can someone please help? Nobody else's wireless device works...
It sounds like the wireless setup in the router may have gotten corrupted. From the wired PC, using a browser type 192.168.2.1 to access the router. It will ask you for a password. The default is to leave it blank. If you've set one, you'll need to give it the one you set. That'll get you into the router. Check the wireless setup. Everything else should be ok, or you wouldn't be able to access the internet from your wired PC.
If you can't find anything wrong, you can try rebooting the router and the modem. Shut both down as well as your wired PC. Wait 30 seconds. Boot the modem, the router and the PC at 30 second intervals.
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Can't connect or even get past setup.
hmmm...
ok, first question:  Are you running the setup CD while the computer has a physical cable connecting it to the router, or are you trying to do this completely over wireless?'
For most wireless routers, initial setup works best using a physical cable.
also, it's possible that the manual reversed username and password:  try USERNAME Admin, BLANK password.
Mar 27, 2008 | Linksys Wireless-G WRT54GX Router...
2wire (1000-000057-000) Modem Logo
2,850 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
