Question about Kenmore Refrigerators
Kenmore 106.5702*601 side by side water dispenser does not want to shut off. If I play with it long enough, as the water runs on the floor, it will eventually shut off. How can I fix it?
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
ghappliances
  • 126 Answers
SOURCE: kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Posted on Sep 10, 2008
vanni7
  • 163 Answers
SOURCE: Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Posted on Jan 03, 2009
  • 77 Answers
SOURCE: remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Posted on Apr 24, 2009
  • 12 Answers
SOURCE: kenmore side by side - water dispenser leaks from time to time.
The problem is most likely at the water inlet valve located at the floor at the back of the refrigerator. These valves have a seal that should close off after use but sometimes stick or get a foreign object in the seat. It is intermittent causing only an occasional leak. Sadly, there is no service to the valve and you can only replace it. Good luck, AJ
Posted on May 22, 2009
Water dispenser won't shut off
Sounds like the ice maker is not shutting off like it should.
Jul 10, 2013 | Kenmore 54603 / 54606 Side by Side...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
We put bleach in dispenser and it ends up on floor
Remove the dispenser tray and clean the tubes found on the bottom side. Also, clean the corresponding tubes on the tub side. The bleach and softener dispensers work on a syphon principal. As the level is raised by water being added, the solutions reach a point to where they overflow. With the caps and tubes, a syphon is created, and will draw the contents of the cups into the washer until the syphon effect is broken when the water shuts off.
Best regards, --W/D--
Mar 06, 2011 | Kenmore Washing Machines
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Jun 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side - water dispenser leaks from time to time.
May 22, 2009 | Frigidaire FRS6R5EMB Side by Side...
Kenmore refridgerator mo. #58251890,water dispenser will not stop
sounds like the switches are getting stuck and not releasing properly. the switches are inexpensive and relatively easy to replace if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
231 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
