Question about Dell Inspiron 5150 Notebook
Flashing cursor on inspiron 5150
NO boot on laptop Slot A Memory installed 'Nothing'
Slot B memory flashing cursor on inspiron 5150 No access to bios to even see anything.
  • Dell Master
  • 32,281 Answers
I assume the power LED is on when you boot up the laptop and the power adapter is OK.
If I understand you, the RAM module is in memory slot A and not in slot B. If not the RAM module needs to be in slot A.
When a laptop doesn't the RAM module may only needs re-seating or the RAM module is faulty.
Re-seat the RAM module, and if this then take the RAM module and get it tested at your friendly computer shop.
Posted on Dec 11, 2009
Flashing number lock, solid cap lock, will not turn on at all
Count the number of flashes. That is the trouble code.
Jan 29, 2014 | Dell Inspiron 1526 Notebook
Vaio VGN-FS980
It you removed the 1- 512 memory did you go to only the bois or did you try to let it boot? if you did not try it with the first stick of memory in and see if it works, if it does not put that stick back in and remove the second one. just because it shows the memory does not mean the memory is bad.
Nov 07, 2007 | Sony VAIO VGN-FS980 Notebook
No video on dell inspiron mini
If it happened after the installation of Win 7, then board malfunction if not very likely. Do you get any video on start up. The Bios should be displayed fine as it is not related to Win 7 OS. However if no display during startup would mean somehow your BIOS got corrupted during the installation. Flashing the BIOS might help
Mar 07, 2012 | Dell Inspiron Mini 10 Notebook
Dell inspiron 1501 won't boot but caps lock flashes continuosly. when i remove memory it doesn't beep
Caps lock flashing indicates faulty memory - it's a POST (Power On Self Test) before BIOS executes. When memory is removed it should indicate "no memory". Carefully re-insert the RAM memory module, check the tiny contacts inside the connector on dust. Then try again.
If there are 2 memory banks (1 one the back, the other under keyboard) remove one RAM memory module.
If capslock keeps on flashing test it with another RAM module.
Jun 30, 2011 | Dell Inspiron 1501 Notebook
I recently took apart my Dell Inspiron E1505 to clean the fan and now it will turn on but has distress lights type flashing on the top of the keyboard. Will not boot. Will not turn screen on. Please help.
Look at your memory again. There are two slots for memory. Make sure that the memory chip you have (if you only have one) is in tha A slot and not the B slot. Otherwise, remove and reseat all of your memory if you have both slots full. This should fix it for you.
Mar 13, 2011 | Dell Inspiron E1505 Notebook
Computer with vista 7 boots up to a black screen with a flashing underscore cursor. I can only use the f10 key. what do i need to do or where do i start to fix this problem.
First Make sure to Remove all external devices and media. Be sure to check the optical drive, flash memory slot and try once again to boot to BIOS by tapping f10 make sure you start tapping the f10 key as soon as you power on the NB if boot to BIOS then do a BIOS default by pressing f9 and then f10 to restart the NB press enter if prompted
check if the issue is resolved or if you not able to get into BIOS by f10 then run the Hard drive test from Diagnostics then is F2
power on the NB tap f2 to boot to Diagnostics and run self test for hard drive and if the fails then hard drive needs to be replaced or if the test passes and still issue is not resolved
then Re-Seat the Memories on then if still issue not resolved
then try F11 recovery this will format the Hard drive an install the fresh copy if operating system still same issue or unable to run recovery then contact manufacturer
Aug 23, 2010 | HP Pavilion dv6000z Notebook
Dell Inspiron 600m not starting up!
I had this same problem with my 600m laptop.  How many times do the lights flash, before they stop flashing?
Cause: There is a physical problem with the computer that it is detecting at startup diagnostics.
Solution:
You should have two pieces of RAM installed. Carefully, remove the memory slot cover.  Swap the 2 pieces of memory you have in there (please follow memory installation and removal for laptops to the letter, by never touching any of the electronic contacts and handling the memory from its sides). Make sure, they sit in the slot properly (to the best you can see). Then, place back the memory cover, very carefully, and screw in.  If you see the memory door cover not closing properly, the RAM might be improperly inserted.  Please go back to the swapping of RAM step. :)
If this didn't work, 1 of the 2 RAM's you have are no longer functioning properly. Please follow the steps to openning the memory door again and remove RAM in "B" slot first.  Then close it and try to start the computer.
If it still doing the same light flashes, open the memory door and remove RAM in slot "A".  then place the RAM you removed from slot "B" into slot "A".  Then start the computer again.
Jan 02, 2009 | Dell Inspiron 600M Notebook
Dell Inspiron 5150 won't boot
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
Mar 19, 2008 | Toshiba Tecra 8100 Notebook
Dell Inspiron 1100 does not see new memory
Install one memory first to any of the memory slots and boot your laptop... then do the same on the other slot with the same memory.
Now do the same step to the other memory...
That is to see if any of the two memory has a problem or to see which memory slot has a problem... You should find a problem in there... that would be memory or the memory slot.
Jan 25, 2008 | Dell Inspiron 1100 Notebook
Dell Inspiron 5150 Notebook Logo
161 people viewed this question
Alun Cox
