Question about Amana SXD524VW Side by Side Refrigerator
How do we access the waterline inside the freezer door?
Our water line broke flush with the bottom of the freezer door. How do we access the water line inside the freezer door? Taking the panel off the inside just was a wall of insulation and no clear access points. Looks like we have to cut the insulation. We need to get in there to splice the waterline back together. Thanks for the help!
  • Grasshopper1 Jan 20, 2008
    Thanks, there was enough line in the freezer door to push it through and out a bit, now it is out the bottom a couple inches, enough to attatch it to the other line. Sure wish hardware stores were open late...
  • Anonymous Mar 25, 2014
    Waterline leaking
    Problem Solver:
  • 9 Answers
The waterline comes out the lower door hinge. Unhook from coupler at bottom. Now go to the despencer and carefully take the cover off some have screws under drip plate or clipped which a flathead screw driver works nicely dont scratch finish. With proper water line usualy 1/8 size about 5foot long snake it down to the bottom hinge and rehook up. In some case if the tube gets kinked you may have to remove door to do it it. Usually pretty easy.
Posted on Jan 20, 2008
Need to replace water line inside freezer door.
Water lines inside doors are typically not serviceable as the insulation is "foam in place". Pulling apart the door and reassembling will be next to impossible. Generally the door would need to be replaced.
Apr 14, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
Internal waterline broke
i would need a model number because in most cases if the water line broke in the door, you would have to replace the whole door assembly.
Dec 30, 2012 | Refrigerators
Need to remove doors from a Shelvador side-by-side fridge to get into house.. How to disconnect water line to door?
Most of the water lines have a quick connect fitting down at the bottom under the unit. Open doors, remove kick plate and follow line back. Should have a connection in that area.
Aug 18, 2012 | Refrigerators
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a refrigerator GE GSS25PGMF and I have no idea how I should get inside of the freezer door. I do not see any screws.
The doors are not made to get into . All parts are accessable from the outside , except , for the water line inside the door .
The liner and waterline , are set on the door , and then insulation material , is then piped into the door .
Oct 09, 2009 | GE Refrigerators
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
Oct 05, 2009 | GE Refrigerators
Water dispenser line leaking at bottom of freezer door hinge, line broken, do i need to remove the inside door panel of freezer door to replace it?
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
Water line going into back of freezer broke
this is usually caused by the defrost cycle malfuctioning causing the freezer water line to freeze and crack. at times this will happen to the defrost drain line also. check the defrost cycle, repair either timer, defrost thermostat or the heating element, then replace the water line. sometimes the water lines will become brittle from age and not getting enough air circulation if it is a built in. good luck i hope this helped you.
May 01, 2009 | Refrigerators
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Whirlpool refrigerator waterline is clogged
go to the back of the ref, trace the incoming water line, it should go to a two pc solenoid valve. if you press water at the front, one of the solenoid should click. the one that didn't click is the one for the ice maker. see if you can detach the water line that comes out of that solenoid. that line goes to the ice maker. you can flush it with water to clean it. be aware that a lot of water would be overflowing inside the ice maker . i hope i was able to solve your problem..
Feb 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Amana SXD524VW Side by Side Refrigerator Logo
286 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
