Question about Dometic Rooftop RV Air Conditioner
I have a dometic Roof Top Rv Air Condtioner and the evaporator coil is freezing up. Could the unit be low on freon. I also noticed the evaporator coil had a noticable amount of dust build up. My thought was to clean the coil however it is very dificult to get to the coil from the inside?
  • 8,404 Answers
It freezes because of a lack of air flow ... and/or ... colmplicating ... high demand with high humidity.
Even worse is running the roof top with the door open in the summer (I see this all the time in the RV park where I work - I'm not saying you are doing this - but I see it all the time. What the heck, the typical transient camper is not paying for the electricity - let it run!)
I hope this helps you
thanks for your interest in FixYa.com
a
Posted on Dec 11, 2009
Dometic roof top sounds like ice rattling inside and spits water drops
ice building on coils due to low freon, dirty filter, dirty coil,or fan speed to low.
Aug 14, 2015 | Dometic Rooftop RV Air Conditioner
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
Sep 30, 2013 | Dometic Rooftop RV Air Conditioner
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
My coils inside of my Dometic roof top ac keep freezing up. How do I clean it? Thanks John
You can buy some coil cleaner at a heating and air supply. There are several brands. Some have to be rinsed off others don't. Use the kind that doesn't have to be rinsed on the evaporator coil.
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
What is the a/c charging pressure on roof top r/v units?
The easiest way to charge a unit is to add freon to the low side until the line sweats and the coil is sweating top to bottom. The pressure depends on the wet bulb temp on the low side line the ambient temp outside and the intake temp inside the
RV. A good unit will start to sweat between 50 to 78 pounds on the low side. good luck
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Roof top a/c is freezing up what can be done?
Check the refrigerant charge. A low charge will cause it to freeze up. May need to have some added. Also check for dirty air filters and make sure the evaporator coil is clean. A restricted airflow will cause it to freeze up also because the air isn't transferring heat in the evaporator. Let me know if this helps.
May 20, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Quick Cool compressor freezing and evaporator coil
Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Quick Cool RV unit
Time to be serviced,could be a small leak and loosing freon, or low air flow due to dirty filter.,
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
207 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
