Question about Garden
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine running, no water will pass through the pump.
  • 68 Answers
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Posted on Feb 08, 2010
Honda gcv160 pressure washer washer has no pressure. Water flows well through it, but no pressure.
I would be happy to advise you further and give you more detailed answers then the others have. Guessing at an engine or unloader problem will not actually assist you in getting your pressure washer up and running again. The most important question is, what is your pressure washer model number? That is the first part of this process. Honda is just the manufacturer of the engine that you have. They don't build pressure washers. If you can provide the model number, you should be able to find this on the cart or frame of the unit, then I can determine what pump you actually have and assist you in determining the actual problem to get your pressure washer up and running again. There are a few issues that can cause this problem, all of which can probably be repaired with minimal cost. If you can provide me with more information I would happy to assist.
Oct 20, 2013 | Honda Black Max 2600 PSI Pressure Washer
Does anyone have a answer as to why all of a sudden theres no water and presure coming out of my jet washer
If there is no water from you power washer it is because the is no water going in. Check fitting is connected properly. When you pull the trigger and the machine is not running you should get water coming out of the nozzle That shows that water from the tap is passing through the machine. As to no pressure that will be a fault in the regulator valve that is not reacting to the trigger setting and allowing the pump to build up pressure. It is still reading as if you haven't pulled the trigger
Feb 24, 2013 | Honda GCV160 Engine
I have a powerboss 3000 psi washer. The engine is running but it is not building pressure.
you may have a bad by-pass pressure control valve.The pump may also have bad seals inside.You can replace the pump but it is very expensive.You can buy a rebuild kit and a new by-pass control at a local supplier.Be careful not to let the motor run more than 30 to 60 seconds after you let go of the trigger.The water in the pump will get extremely hot and destroy your pump.
Oct 17, 2010 | Psi PowerBoss 20262 Pressure Washer
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Garden Logo
560 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
