Question about GE Spacemaker JVM1640SJ Microwave Oven
It doesn't heat anymore. About 5 years old only.
It doesn't heat anymore. About 5 years old only. All other functions, clock, timer, etc work but no heating.
  • donbev6 Dec 11, 2009
    Can you "see" if the contacts have been damaged? How can you tell?
  • GE Master
  • 8,404 Answers
Check the door safety switch. When they go bad, they oven doesn't know if the door is closed or not. Find them inside on the side opposite the hinge. They go bad because we (read "you and me" open the door with the oven running and that cooks the contacts on these little switches.
Need more info? Post a comment to this question
thanks for your interest in fixYa.com
Posted on Dec 11, 2009
Testimonial: "Not being electricians, we picked out a new oven today. However your comment made sense to the salesman who would pass it on to customers to be aware"
  • A Miller Dec 11, 2009
    You will have to test the switch(s) with a continuity tester or a volt/ohm meter on OHM setting. If you don't have such a thing, you can purchase at Ace Hardware or other fine store in your community for about $15.00. Instructions will come with the tool.
    Remove the cover - be careful to not touch the leads on the silver can like thing - this is a high voltage capacitor. If charged (and they may remain charged for days after being unlugged) they can be lethal. The micro switche(s) are about 1/2 X 1 inch and about 3/16 thick. Probably black but can be any color. They will be activated by your door latch. Watch the action as you open and close the door, with the cover off and with the oven unplugged, OF COURSE. Listen carefully as you open and close the door, you should hear a tiny "click".
    Test with the door both open and closed. The switch should read "short" (contacts closed) with the door closed and "open" (contacts open) with the door open. Your oven may use an alternative scheme and be backwards. Point is, in one position, the switch should read one way and the other position it should read the other way.
    The switches will have three connections, probably only two are used. One is called "normally open" or NO, and the other way is called "normally closed" or NC. The third connection is "COM" or common. Don't try to reconcile this, just be aware of it. If you replace the switch, you must use the same terminals. Take a picture with your cell telephone and/or write it down.
    If your switch reads the same open as closed, replace it.
    Find a replacement at a FixYa.com advertiser, your local appliance parts place or visit www.repairclinic.com. Be prepared to provide make, model, series, serial number, date of manufacturer where ever you go for the parts.
    What is going on? These switches tell the oven whether the door is open or closed. If the door is closed, a good switch notifies the oven that that condition (door closed) has been met and it is ok to turn on the magnetron, the device that makes the 'heat'. If the door is open, or if the switch is bad causing the oven to THINK the door is open, the oven thinks the door is open and will not turn on the magnetron. The radiation made by the magnetron is dangerous to people and that is the reason for this safety measure.
    The reason these tiny switches go bad is we (read most of us) open the door while the oven is operating. When we do this, the tiny contacts inside the switch (which are electrically hot) spark. When this happens enough times, the contacts are burned and will eventually not close properly.
    Make sense?
    There are other things that can cause what you describe but in my experience (I am NOT a appliance repair guy), this is the most common reason for failure.
    I hope this clarifies your question and helps you make your repair.
    Thanks for your interest in FixYa.com
    please remember to vote -
    a
    Thanks for the feedback ... this is doable ... but Im also glad you have a new oven to use.
    Thanks for your interestg in FixYa.com
The oven doesn't work, the timer works and the light comes on
This is a strong indicator the magnetron has failed "heats food" and is the heart of the system. If microwave oven is a few years old better to invest in new.
Mar 06, 2012 | Cuisinart Microwave Ovens
Microwave Model (1992) J KP6460P1B6 Doesn't heat food. Timer, clock, etc. work fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Aug 25, 2011 | Microwave Ovens
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
344 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
