Question about Whirlpool Water Heaters
No hot water-pushed reset - Whirlpool Water Heaters
  • 31 Answers
The heating element is probably bad.
Posted on Dec 11, 2009
Where is the reset button on a electric hot water heater Model # ME30H6-S45100 Serial # 1643103783645. I have no hot water and I want to check the reset button.
didnt specify unit--- generic answer --- on most where the thermostat and element connections are is usually a red reset button to push
Jun 18, 2017 | Water Water Heaters
No hot water
1) Electric water heater? Push reset button. Check if tank has hot water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
2) March 2013. Add a comment and say what type, brand heat you have
Mar 07, 2013 | Water Heaters
State Water heater pushed button to turn water down - all lights were lit initially.now no hot water - tried to reset - not resetting - help!
Which water heater do you have?
Is this gas or electric, tank or tankless?
What button did you push to turn water down??
Do you mean turn down water temperature?
What lights do you have that are lighting up?
Aug 11, 2012 | Water Heaters
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
Hot water gets too hot trips off at tank then water gets cool and i push reset button and water gets hot again real hot thentrips off again
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
Mar 21, 2010 | RELIANCE ELECTRIC WATER HEATER
Push the reset butom and there's hot water, but about a minute later, hot water stops flowing. If I want hot water, I have to reset it over and over again.
Too many possibilities to solve without being there. If you have to reset it, that means that one of the many safety switches kicked in. Be careful that you don't make it a habit of resetting it without getting it checked, doing so will mostly likely cause a lot more problems.
Mar 18, 2010 | Stiebel Eltron 3-2 Tankless Electric Water...
No hot water...where is the reset button on the 81vh40d hot water heater by Rheem
the reset is under the top cover, take the screws out and there will be a plastic sheild pull it off DO NOT TOUCH ANY WIRES push the reset button you should here it come on,, if there is any water present do not turn it on but find the source of water and fix or replace the water heater
Jun 07, 2009 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
