Toshiba Laptop approx 3 years old. It fell out of
Toshiba Laptop approx 3 years old. It slipped out of the case it was in and fell about 6 inches onto the floor. Since then it will work but only when plugged in. More recently the touchpad has stopped working. I attached a mouse and it works OK. Any suggestions? Have either/both fixed or not? Original cost was $500-600. Thank you!
    Scholar:
  • 155 Answers
Please handle your PC with care. Since it fell abt 6 in., it must have some connection problem that will still be repeated as soon as it bangs. If it doesn't work in few days from now, check the HDD it may have caused damage because of the fall. Then if you can open any board, unplug connections from outlets then press soldered connections in the motherboard.
Just a pre-caution. But if it persist, see your supplier's technician.
Thanks
Posted on Dec 11, 2009
Alternator might be bad. car slowly dies while driving
no year, ? no model ,lots of years, lots of model Acura's
the charge lamp glows with the ALT does dead..
is it?
and then the battery voltage drops, from 12.6vdc to 12v and lamps
dim , every inch of the way as the battery discharges.
can be lots of causes, not just ALT bad.
1: fuse blown in engine bay
2: bad battery ,
3: battery cables corroded, (big time fail rates)
4: bad alternator ground or its other wires.....
5: fan belt fell off or slips.
6: more if we had year, and model.
Jan 20, 2014 | Acura Cars & Trucks
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
While using my toshiba laptop the computer screen went black
How old is it ?
I had one that was about 3 years old. Did the same thing - It was the kiss of death.
Took it to the computer shop to fix, would have cost more to fix it than buyiong a new one.
Hope that's not the case with yours - good luck
Feb 13, 2011 | Toshiba Computers & Internet
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I HAVE A PROVIEW MONITOR 22 INCH. PL2230 APPROX.
It is out of warranty and not worth repairing.
Jul 19, 2009 | Computers & Internet
Toshiba Satellite P25-S5092-display problems
what you need to do is replace the backlight to solve the display prob and as far as the fan and being that old you should replace the fan
Oct 08, 2008 | Computers & Internet
Toshiba laptop won't turn on
Several things could cause this problem. Be sure the battery is charged for one. For two, it could be the power supply. If it is the power supply, you will need to bring it into a shop. If it makes any sound or has any light on, the power supply may not be the problem. Good Luck!
Jul 09, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
