Question about Dewalt 18 Volt Compact Drill Kit
DW984 Chuck problem
I have a DeWalt DW984 with a chuck stuck in the big /open position and can't get it to close to a smaller position.
Can you please give some advice or tips.
Regards
Jaco
  • 31 Answers
WD-40 works well on most power tools for freeing up stuck parts without damaging the drill. It's also good for displacing any water that may have gotten in it.
Posted on Dec 11, 2009
My dewalt d21008 drill is stuck in a smaller size bit opening . No bit in the chuck. It just will not open up??
hi
clump the drill in a good size vice then use 36" stilson spanner
adjustable adjust to fit the chuck then an do
Mar 08, 2017 | Dewalt Drills
I have a DeWalt DW505 hammer drill. I was drilling into concrete and my bit came out. After several attempts to drill again, I noticed the drill chuck was not holding the bit. I opened the chuck all the...
Hi Ken, sadly it sounds like the chuck is past its best. The cogs inside the chuck have most probably worn. If you can get the chuck off try clamping it in a vice and use some pump pliers to undo it. Failing that you will need a new chuck which you may be able to get at a good diy store.
Sep 14, 2013 | Dewalt DW505 Electric hammer drills
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
Dewalt drill. I have a stuck chuck.
Hi there.
spray some oil into it and tap it lightly with a small hammer. Then hold the chuck and gently squeese the trigger in forward setting and backward setting. Do not use full force on backward setting.
This should do the trick.
Iceman.
Nov 10, 2009 | Dewalt Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Having problem to remove chuck to replace it on dewalt dc988 18v
Inside the chuck is a left-handed screw. torx (star) T20. When you get it out, take an allen wrench and (if you can tighten it up at all, tighten the **** out of it). If not, find an allen wrench, a tiny bit smaller than the space allowed. Now, get a nice big hammer. The chuck is right handed thread. And knock it, spinning the chuck off the spindle. May take a few whacks. Use the edge of a workbench to keep it stationery if need be. Please rate me
Jun 08, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 volt cordless drill the chuck is stuck in the fully open position and wont close
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Apr 30, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Locking ring split on keyless chuck
First you need to shift the tool to the low position, turn the clutch setting to the drill only position. Open the jaws and remove the chuck retaining screw it is LH threads. After all this find a bent handle allen wrench about the size of the chuck capacity and insert the smaller end in chuck and tighten. Put the chuck on a block or wood or workbench with the wrench at about a 30 degree angle so you can hit the wrench counterclockwise. Strike it with a hammer, it might take a couple times but this usually works. Good Luck
Jan 04, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
457 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
