CHanging Belt Maytag DE410 Dryer Q#2: Opening Top
Here is the answer I received from last qestion... My only problem is that I dont see any \'\'star\'\' screws on the back of the machine to release the top of the dryer lid. Do yo umean screws on the back of the part the has the timer and on/off switch/timer etc? Please advise. Thanks again......
Previous Answer.....
Most of the time these models have screws in the back of the machine on the top lid. You\'ll need to get over behind the dryer to access this panel. You\'ll need a \'\'star\'\' type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you\'re good to go
  • 8,404 Answers
Pop the top ... usually held down with spring clips
Be careful of the finish ...
Let me know what happens ...
Post a comment here for additional information/instruction
thanks for your interst in FixYa.com
Posted on Dec 11, 2009
Re Maytag dryer model DE410, serial number 285802, series 01. How much of machine needs to be taken apart to tighten blower fan on end of motor shaft. Thanks. Murray bally.duff@sympatico.ca
Sorry to read about your problem, I hope this helps you out.
all most all of it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
How do I change the tumbler belt on a MayTag DE410 Electric Dryer?
simple remove the two phillips head screws at the bottom of the front panel lift up from the bottom and remove the front panel don't forget to unplug the two wires that go to the door switch and set the front panel aside remove the 4 5/16 inch screws that hold the bulk head on remove the front bulk head and set it aside take out your old belt ,put your new belt around the tube and run it around your spring loaded tension roller and around the motor pulley reassemble the dryer and test thats it
Apr 03, 2010 | Maytag Dryers
Changing a dryer belt on a Maytag DE410
in some models you do it from the front the drum sits on 2 bogie wheels and the belt sits behind ,lift drum off bogie wheels and thread belt around pulley it should be on a spring tensioner and it allows you to swing pulley up or down try to thread belt around drum and replace drum back on bogie wheels.... in some dryers you may need to thread belt on drum and then onto pulley good luck
Dec 18, 2009 | Dryers
Belt change on a Maytag DE410
Most of the time these models have screws in the back of the machine on the top lid. You'll need to get over behind the dryer to access this panel. You'll need a "star" type screwdriver (most come in a set). Remove the top lid to expose the drum. The belt will run around the drum and down around the safety cut out switch. This switch is most likely a teflon or plastic wheel that the belt loops around. After installing the belt, replace all of the screws and you're good to go!
Dec 11, 2009 | Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Need to change belt on maytag dryer but dont know how to do it on this model . any help would be great
Get the Model number and order a Dryer Maint Kit from either of these sites.
http://www.partselect.com/
http://www.repairclinic.com/
If you have the belt already then open the dryer door and there should be a couple screws in the opening where the door normally closes at the top. Remove those and then the door should be able to completely come off then you will have access to the belt area.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Sep 02, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
