Question about T-Mobile Wing™ Smartphone
My dumass WING
I got ma phone on jan 16 2008 and it was working perfectly ok but as soon as I charged it it would keep scrolling down automaticaly its making my backlight stay on and its making me pist . plz help me before i burn ma phone or before i put it in the microwave
    New Friend:
  • 51 Answers
Lol.. sorry for laughing but that's funny... i would recommend for you to take the battery off for 15 seconds and put it back again. If this didn't work go to START-SETTING-BACKLIGHT... then you will see of how to save the battery power and also the external power. Try this and let me know if your phone is been fixed. thank you goodluck
Posted on Jan 20, 2008
Unlock code for a lg rumor cell phone
Hello and Welcome to FixYa!
First of all try default code 0000 or 1234 or Unlocking of LG Rumor become possible by entering "Last 4 of your phone number"
If it don't work then type in ##3282## in your phone and then highlight advanced and click OK or menu then highlight view and click OK or menu. Scroll down till you see lock code and press OK or menu. Change it and your done!Try this i hope it works. If it not works then just give me a comments i will further help you.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemedThank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 21, 2011 | LG RUMOR Cellular Phone
Tip
Will this work on a samsung Myshot II phone I have cricket service and my phone...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Mar 15, 2010 | T-Mobile MDA
T-Mobile Wing rings normally when calls are received and calls can be dialed OK. HOWEVER, when connected on an incoming or outgoing call, I cannot hear the other party and they cannot hear me. I tried the...
I hate to say it but you might need to hard-reset the phone. If you choose to do so BACK UP YOUR DATA first. You can get a free program called "PIM Backup." This will let you back up all of your contacts, emails, etc. (all personal information). To hard reset, hold down both of the soft keys at the same time, then simultaneously use your stylus to hit the reset button. You should get a black screen with some text on it asking if you want to hard reset. Press the "send" key to confirm. If you don't get the screen right away keep trying as it doesn't work perfectly every time.
Sep 01, 2009 | T-Mobile Wing™ Smartphone
My i9 will not turnon
right no1 the phone comes with 2 batterys which have charge try the other battery if that doesent work connect the phne via usb to a computor it should turn on automaticaly and start to charge then you should after a few min be able to turn phone on fully keep you battery fully charged dont let it completly run down as these phones are prone to this problem
Jan 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Playing music
its illegal to play 1 song after another automaticaly
Apr 12, 2008 | Sony Ericsson K800i Cellular Phone
BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
Mar 21, 2008 | Lands Phones
Button stuck?
or course, powercycle....if that doesnt work, a master reset will be needed.....because it sounds like there might be somehitng stuck on the screen in the corner for make it scroll around, clean the screen with a qtip and rubbing alchohol.....if that doesnt work, try a software reset. with the phone off, you will have to press and hold the button withthe lines on them and press the power button.....release the powerbutton.....the phoen should turn on and go to a black screen with white writing....release the soft keys here and press the green call button...it will reset the phone, but in turn, you will loose your info that is not stored on the sim or media card...
this is hard to do, so if you can navigate through the phone go to start, setttings, system, clear storage. it does the same thing. good luck :)
Dec 31, 2007 | T-Mobile Wing™ Smartphone
Tmobile Wing won't stop scrolling
Could be the touch screen, fold a piece of paper in half and run it around the screen and make sure nothing is under the lip.
Dec 13, 2007 | T-Mobile Wing™ Smartphone
PHONE JUST STOPPED WORKING
use the factory charger and if you are call tmobile and tell them u want to do a hanset exchance!!!
Nov 28, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
48 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
