Question about GE WJRR4170E Top Load Washer
Over fills and drains washes with no water (Replaced Timer)
  • 57 Answers
Chcek that there is not a build up of detergent / dirt in the tube that joins the bottom of the tub to the pressure switch. You can check the pressure switch by blowing into it, listening for a click and checking continuity across the terminals
Posted on Dec 11, 2009
SOURCE:
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    Tip
    The washing machine will not run any cycle?
    If the washing machine is filling with water and agitating.but after agitating it will not go to spin cycle and also if you try to drain the water and no drain cycle happens then its the fault in the timer of the washing machine.The timer needs to be replaced to solve this issue.If the timer check out OK.Then its the problem of cold water supply in the washer.Check whether cold water supply like is turned on.If not then turn it On.If the line is turned on then check is the cold water entering the machine.if not then check the hose from where the cold water enters the machine.its blocked or got cracked and leaking.the hose needs to be replaced in this case.This has to be checked.This will help.Thanks.
    on Mar 18, 2010 | Washing Machines
    Washer stopped at the drain cycle Model LSR8233JQ1
    Could be either a bad lid switch or a bad water valve.
    Set the timer dial to SPIN and turn the machine on.
    If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
    Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
    If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
    If it does not fill with COLD water and the screen is clear,replace the water valve.
    Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
    I have a Fridgidair and it won't drain the water, it pumps the water in and fills but won't drain after it cycles. Please advice!
    More than likely check to see if the drain pump is getting any power from the timer, if it is getting power from the timer than the actual drain pump needs to be replaced.If there is NO POWER coming from the timer, than replace the timer.
    Aug 14, 2009 | Frigidaire FWS833A Top Load Washer
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Jun 18, 2009 | GE WSXH208A Front Load Washer
    GE SpaceMaker washing machine does not stop filling.
    try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
    Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
    That is probably a problem with the timer.
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Frigidaire front load washing machine won't stop filling
    it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    GE WJRR4170E Top Load Washer Logo
    Top GE Washing Machines Experts
    Marvin
    Marvin
    jimorris77
    Gerry Harvey
    Gerry Harvey
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
