Have not used it for 3 months and just moved it. The print is perfect, however There are black lines running vertically and faint bands of color running horizontally on the printed side of the paper and the obverse side has faint colored band running horizontally. I have printed 4 pages all with the same results. Please help!
  • 4,472 Answers
First off what is the make and model of the print. There are a lot of possibilities at this point. You may want to try cleaning the rollers first. Once I have more information I can assist you further.
Thank you,
Lee
Posted on Dec 11, 2009
Black vertical band on tv screen
Actually I am not sure about this one, but I like to suggest to leave the unit running for at least 24 hours and see what happens. Going by the amount of time it has not being used it is hard to tell what actually occurs, the advice is to leave it on standby for any period of time. See what happens anyway, you can't do anymore damage than you already got can you? Else, keep switching it on and off, it may clear it that way. If you are able get a update on-line, re-program you tv it worked for my Samsung 39 inch. Good Luck
Aug 15, 2014 | Televison & Video
HP 2600n will not print black after lens cleaning (other 3 colors are perfect)
check supply status, configuration page, how is look if black only getting miss alignment then check formatted board/dc controller
Jun 26, 2013 | HP Color LaserJet 2600n Printer
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Samsung CLP-300N printer shows faint banding
Developer roller worned,common problem.roller can be changed,take drum out,2 screw 1 on the side near toner excess bin and 2nd on roller.
Jun 24, 2009 | Samsung CLP-300N - - color - laser -...
Epson r300 - banding problems on print out
Nozzle check is fine? I am not sure. Check again. There is transverse and vertical lines. Is it perfect? Turn off printer, move head to center, put wet tissue with hot water at head cleaning mech. (pad). move head to parking position, wait for 15 minutes, repeat for 3 times. Check nozzle.
Jun 11, 2009 | Epson Stylus Photo R300 InkJet Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Without actually seeing a print sample or the machine, my bet would be on the black print cartridge. Even though it reads a an acceptable level of toner, the cartridge itself sounds like it has developed a proble. 1. It's the most obvious 2. It't the cheapest place to start. If it does not correct the problem, you can still use it later. 3. It's the problem in about 80% of these types of cases. 4. I know it should be fine, but if things didn't go wrong, I wouldn't have a job! Let me know. If not we'll investigate further. Ed
37 people viewed this question
k24674
Marvin
Marvin
