Question about Garmin Foretrex 101 GPS Receiver
Garmin Foretrex 101 won't respond to pushed buttons
When I place fresh batteries in the GPS, the unit starts up but won't respond to a push on any buttons or a push and hold on any buttons. I have to remove the batteries to charge down. Is there any way to reset the unit?
  • 2 more comments
  • HandcarTrek Sep 03, 2008
    I have assumed that the Foretrex had seen its last, so I have moved on to a new Foretrex 205 instead.
  • hotty198 Nov 05, 2008
    anybody get it working again? same problem. just started yesterday for some reason.
  • Anonymous May 02, 2009
    Unit will only power on with batteries placed in it. All buttons done want to work. I have uploaded new software from garmin and still no joy !!
  • phopkins May 20, 2009
    Just put new batterys into my 101 and when powered on I only get the software revision screen..help
While this may not be a fully working solution, have you guys tried pressing and holding the page button while at the same time pressing power. hold them in for a while and see what happens. it might just work. mine is sort of working after doing it a couple of times. page+power same time and hold longer than 5 sec just to be sure.
Posted on Nov 05, 2008
Did you ever find a solution?? i'm having the same problem
Posted on Sep 03, 2008
I plugged in my Garmin Nuvi 40LM to the computer and got the updates. But my keyboard is still not responding correctly. I push 5 and get a 6 or push T and get a Y. Any ideas?
Try recalibrating the display. Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and hold it there while pushing down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press all of the dots as they are presented. Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display. If this doesn't resolves your problem. then your touchscreen may be defective.
Feb 25, 2016 | Garmin Nuvi 40Lm - Gps Receiver
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    My sgx is locked up and won't do anything - won't
    Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
    Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
    Hi i get the greeenlight on charging but then wont turn on sally
    if the unit has been unplugged for a while and the battery has gone flat, you will need to hold the on button for a few seconds to re start it. After that , it will be ok. Just a short push of the button as usual
    Oct 02, 2010 | Tomtom GO 510 GPS Receiver
    I put the 305 on the charger at night and I see the charging in progress message. When I wake up it is blank and the unit will not power up? It's like the battery is dead and it won't respond to the...
    Over charging sometimes does that effect.
    However, best is reset the device. Try soft reset first, if not sufficient, try hard reset.
    Soft reset : Hold mode and lap/reset for 10 seconds, then release.
    Hold start button then for 10 seconds, device should restart.
    Hard reset : Hold mode and start button. 10seconds after, still holding them, pulse press lap/reset button, then release all.
    You should get a screen asking to confirm reset to factory settings. You'll loose all data by this, but device should restart with normal behavior.
    Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
    When i hit the lower right hand coner the unit responds letters above? the screen is not synced with where i push?
    To reset the screen sync, press and hold the battery icon for a few seconds (you may have to press below it with your fault). You'll then go into a diagnostic mode, scroll through the screens using the buttons at the bottom until you get to a menu item which allows you to re-sync the screen. Eventually you'll cycle through all the pages to the start and can press exit to return to normal mode.
    May 29, 2010 | Garmin nuvi 200W GPS Receiver
    Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
    My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
    May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
    Garmin nuvi 260 won't turn on
    There is a reset button on the bottom of the unit. Push it in with the tip of a pen. Worked for me!
    Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
    The laptop will not start... it does not hold its charge and when the charger is in it still does not respond. it flashes an orange light at the battery light but nothing else happens. i have taken out the...
    You may need to replace the battery. The battery is not holding charge so it is likely bad; but worse, it may be overloading the supply and keeping the unit from starting. Some supplies will not operate without a battery in place. If it worked previously, then you are fairly safe in the battery investment. If you don't know if it works, you will have to decide, as a starting with a fresh battery may still uncover other problems.
    Nov 26, 2008 | Toshiba Computers & Internet
    Garmin Foretrex 101 GPS Receiver Logo
    779 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Steve
    Will Halftowaite
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
