Question about Goodman CLJ30AR32 Air Conditioner
My heater never stops working even if i turn it off
  • 8,404 Answers
There is a several minute delay from the time you turn this device off until it actually goes off. Reason for this is for the air conditioner to properly cycle off OR for the heater to properly cool down and shut off. This is not a light you are turning on and off, it is a complicated (for good reason) heating and/or cooling device.
Every time you change the setting, you add more time for the thing to take the proper action.
There is also a setting on most Goodman devices that will keep the fan going ... no matter what (well, almost no matter what)
I'm sure your instruction manual will explain these things in detail, after some number of pages of legal notices. Im equally certain your installer can be of further assistance with these concerns.
Thank you for your interest in FixYa.com
Please vore
thanks
a
Posted on Dec 11, 2009
Heater doesnt work
did you check the fuses ? relays? does it blow any air at all? could be blower went bad and blew fuse, or a relay failed, check fuses first.
Jan 11, 2014 | 2005 Buick Rendezvous
Wont stay working
What won't stay working? Does hot air come out when you turn it on and then is stops working, or does it not even heat?
Oct 17, 2013 | Goodman GMS80903BNA Heater
My sunbeam large room ceramic heater just stopped working, I havent even had it for 2 months what can I do
Can't you exchange it at the store where you bought it and get a different one? It certainly shouldn't stop working after only two months of use.
Nov 26, 2012 | Heating & Cooling
Heater blower motor stopped working still just put it in
The heater resistor has probably gone out. It should be located in the blower housing.
Oct 09, 2017 | 1991 Chevrolet S-10 Blazer
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
On my santa fe the heater wont turn on. I have
It could be your blower switch, but more than likely it's a resistor that is usually a part of the blower assembly, and it operates the speeds. Doesn't cost much but can be tricky installing. If you had one or two speeds not working, initially, eventually all may stop. If fan stopped working and all speeds had been operating, then you may have a bad wire or blower motor. Also, check your manual for fuses, as there may be a compartment inside the vehicle as well as one under the hood.
Dec 27, 2009 | 2002 Hyundai Santa Fe
How do I stop the spa from starting up and switching the heater on after a power cut?. Pump 1 will run the first time switched on,but if switched on again, it sometimes just stops and wont start for some...
It's not possible to stop the spa from starting up after a power loss. Most spas go through a self test then try to reach the last set temperature. Pump 1 usually runs the filter/heater, once it's activated it should run for 20min or until you turn it off. The high speed on pump 1 should always work. One problem with the pump may be that it's heating up and the internal high limit won't let it turn on. When you shut the pump off, the motor gets even hotter for a period of time since the fan is not turning, it may be getting hot enough to trip the internal high limit so that it won't turn on until the motor cools down. It won't turn on even if the topside control indicated that it should be on.
Dec 01, 2009 | Pool & Spa
Vornado VH2 stopped working. on/off not functioning
if it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
Jan 08, 2009 | Vornado VH2 Compact Heater
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Goodman CLJ30AR32 Air Conditioner Logo
44 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
