Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell 2xs water not coming out of machine, but comes out of hose when pressed. Plz help??????????Thanks
    Problem Solver:
  • 5 Answers
THE JETS UNDERNEATH THE MACHINE THAT SHOOT THE WATER OUT ARE PROBLY CLOGGED WITH DETERGENT. Get a pin and try to clean them from underneath the machine . Ten put some hot , hot water in and wait about 5 mins. then try it out.
Posted on Dec 15, 2009
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
Re: model 3522-5 Bissell proforce bagged vacuum hoses clogged
Worked perfectly. Thanks, jade_greeney. We thought we were going to have to shell out $100+ for a new vacuum.
Jul 03, 2009 | Bissell 3522 PowerForce Bagged Upright...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Bissell pro heat water will not disperse from
If the red spray pieces are not clogged but the Bissell still will not dispense water, then I would say the next most likely causes of your issue was either no soap in the tank, or a burnt out water pump. But since you can get water through the tools, I don't see how that's possible. I think it's still the sprayers. When you say you stuck a needle in the eye holes of the two red spray pieces, did you actually take the two red spray pieces off the hoses to do this? And then after pushing through a needle, did you try blowing through the red spray pieces? If you can't blow air through them, they're still clogged and water won't go through, either. Here's how to get the red spray pieces off the Bissell: Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits. Only work on one sprayer at a time so you can see how it goes back together. As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush. Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.) With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care. When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell. Now do the same for the other red water sprayer. The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It?s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base. You might want to prime the pumps. Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time. Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times. As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it?? Good luck!
Jun 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell pro heat water wont come out
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
May 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
When I turn on my bissell proheat 9200-T, it starts leaking
It could be that one of the hoses came loose on the inside. It would be best to take out the screws in the black plate, and open it up to see where the source of the leak is on the inside.
Apr 10, 2009 | Bissell 9200 Upright Vacuum
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Proheat 2 solution tank
First make sure the solution bottle is seated correctly and the machine solution inlet is free from any debris
try the hose part of the machine,
See if water comes out of the hose ; Set the dial to heavy traffic, then put a pencil mark on the solution bottle level with the solution liquid ,
See if the solution level goes down
see if water is coming out of the spray tips under the machine
The spray tips could be blocked .
Nov 24, 2007 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
233 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
