Question about Dynex DX-L42-10A 42 in. LCD TV
How do i get my 42 inch Dynex television to show in 1080p . because right now it only shows in 1080i
  • Dynex Master
  • 3,866 Answers
This is all depending on the programming not the TV. If the signal is 1080I that is what it is now if it is in 1080p depending on your TV if it supports 1080p it will be displayed as such.
You can also check under your menu settings to make sure your TV is set for the max resolution the signal is coming in on.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 11, 2009
A BOX WITH THE FOLLOWING INFO KEEPS POPPING UP ON THE SCREEN: 480P SD, HOWEVER I HAVE A 1080P FLAT SCREEN. IS THIS A CABLE ISSUE OR A DYNEX ISSUE?
It is most likely a cable issue. If you have a 1080p television your tv might be trying to communicate with your cable box. If your cable is broadcasted in standard definition that message can show up. I would recommend checking with your cable company and see if you have HD channels or not.
Aug 01, 2012 | Dynex DX-L42-10A 42 in. LCD TV
How much will it cost me to e replace a dynex lcd 42 inch flat screen tv
Dynex is not a seller of TV's up to that size. The closest I could find is a 37" Class / 1080p / 60Hz / LCD HDTV on amazon.
You can see it Here: http://www.amazon.com/DynexTM-Class-1080p-60Hz-HDTV/dp/B004896RCY/ref=sr_1_5?s=tv&ie=UTF8&qid=1306529090&sr=1-5
May 27, 2011 | Televison & Video
Can 1080i be changed to 1080p?
The device you connected to your television determines whether or not you get 1080i or 1080p. The television automatically shows the programming in 1080i or 1080p depending upon what the connected equipment is set to. There is no way to change this on the television itself. Currently the only way to get 1080p is with a bluray player or bluray on demand programming from the cable/satellite companies. HD on cable and satellite is 1080i for now.
Nov 04, 2010 | Vizio Televison & Video
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
How to get toshiba 42 inch to 1080 from 720
The set doesn't do that, only the broadcast stations can. Hardly anyone broadcast in 1080p. 99% broadcast in 1080i = 720p. Your set will produce it if it can get it. 1080p broadcast is probably a few years away. A Blueray DVD player with a 1080p disc will get it for you. I hope this explains it for you.
Oct 31, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
Direct TV says that they will offer 1080p quality. Need update
1080I and 1080P is more than a software difference. It is a hardware difference in the TV's capability to display a progressive picture at that resolution, so no software update will be able to help you. The processors are only capable of 1080 Interlace, and the TV is only capable of 720 Progressive or 1080 Interlace at it's maximum performance.
Hope this helps you...
Jan 06, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
How to get 1080p?
in addition many TV service providers are unable to send a true HD signal. the max is 720p or 1080i as refered to above. some sattelite companies are beginning to dabble in it but nothing full swing as of yet.
Dec 27, 2008 | Polaroid FLM-4201 42 in. LCD Television
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Dynex DX-L42-10A 42 in. LCD TV Logo
119 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
