Question about Brother Office Equipment & Supplies
MFC7420 Brother Printer. Paper jamming. 1) Bought new Brother toner and drum from Databazaar.com. Replaced paper. Paper still jamming. 2)Tried another new Brother toner. Paper still jamming. 3) Cleaned the feed and separator rollers in front. Cleaned the sheet separator pad. Paper still jamming. I can get maybe one sheet to print. Next sheets jam. When I open the back cover, I see the paper wound around and up on the brown fuser roller. What can be wrong?
  • hconrath Dec 11, 2009
    Can the fuser roller be cleaned?
  • 3,741 Answers
Where you place the paper in the tray.the end of the paper touches to the roller.beside that roller there are gears on both the ends of the roller.and on the base below the roller there is a thin pad pulling the paper. now the problem is either of this three options or may be all of three.
1) the gears are cracked or worn out.
2) the paper pulling pad is gor rubbed out.
3) the roller are not having the traction to pull the paper.
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
you can get the required parts at local printer repair store or also you can get this parts replaced at this store also by there repair technicians.the cost of all the three parts will not be more then $30.
its not a very tough job to do but disassembling the printer and reaching the inner rollers,gears and pad is bit tough job and very much time consuming.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 11, 2009
  • 428 Answers
Try brushing the rollers very well. When inner rollers fail to receive paper and roll them out, paper jam results. Usually dust on surface of rollers could cause it. Toner cartridge has nothing to do with paper jam. Also when paper is too thin grammage it results in winding up around rollers. Just get a brush and brush all rollers thoroughly and make sure using paper of at least 80grams.
Paper jam in rear
Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
Feb 19, 2014 | Brother MFC Office Equipment & Supplies
Rear cover jammed
Hi madeleine,
1.Press the cover release button and then open the front cover.
2.Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
4.Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5.Using both hands, gently pull the jammed paper out of the fuser unit.
6.Put the drum unit and toner cartridge assembly back in the printer (press firmly).
Fully close the front and back covers.
Pull the duplex tray completely out of the printer.
7.Pull the the jammed paper out of the printer or the duplex tray.
8.Put the duplex tray back in the printer.
9. Make sure that the Back Cover LED and the Paper LED are off and then, the Status LED lights green.
Jan 29, 2014 | Brother MFC-5460CN All-In-One InkJet...
Brother 2270 laser printer started jamming every time, after I installed a new toner. It was a Brother toner, at that. Anyone experience this?
Silly question first - is the drum unit DR2225 installed?
Check the toner cartridge sits firmly in the drum and that the drum is pushed all the way forward in the internal cavity. If the paper is jamming at the paper pick up roller ie in the paper tray, clean the paper pick up roller with a drop of meths and a drop of detergent on a damp cloth. If the paper jams in the drum unit, check the clear plastic guide flaps are straight and do not catch the paper. Also check that there is not a piece of paper caught in the drum unit. If the paper gets part way through the drum and then jams, check the fuser at the back for a piece of paper crumpled up inside the fuser. If the printer is trying to take ALL the paper at once, check and clean the paper separation shoe in the paper tray.
Jan 03, 2018 | Brother MFC-7820N Laser Printer
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Nov 07, 2010 | Brother HL 5170DN Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Paper jam on Brother HL-1270N
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
Feb 23, 2009 | Brother HL-2040 Laser Printer
Paper jam on initial feed
It sounds to me like your pickup rollers are worn. You should order a new set and replace them. That should solve your paper jam issue.
Feb 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Brother MFC 7420 Paper Jam. Paper will feed from tray to Toner/Drum then Jam. Feeds only about 4 inches of the sheet then Jams. I have replaced the toner/drum unit. Any help is appreciated. Thanks.
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Nov 13, 2007 | Brother MFC 7420 All-In-One Laser Printer
54 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
