Samsung remote I need to find the codes to use this remote for a sharp tv. I have been getting bounced around to all different sites and can't find the right one. Can u help? Thank You. It is a Samsung Universal Remote model # 10109E
  • beyondsat May 11, 2010
    This remote was designed to only work certain samsung TVs. The TV mode is not programable. Remotes that come with specific TVs are not intended to control any other TVs. Your best bet is to call Sharp and see if they can send you the correct remote. They cost anywhere between $15-$50. You can also get a any basic universal remote from walmart.
IrishDruid
  • 2712 Answers
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
aprmaejun
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: chunghop
I NEED CODES FOR SHARP REMOTE CONTROL RM-332E CHUNGHOP
Posted on Jul 02, 2009
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
Changed tv but can't get genie to change channels it turns on and off it was hooked to Samsung and not on a sharp tv
There are several "Genies"....can you be more specific?
Have you changed the Code from the Samsung to the Sharp?
The Code is different and the remote needs the correct Code
You should be able to do an Automatic Code Search if you
don't have the User Manual with the Code
Aug 25, 2018 | Samsung Televison & Video
What is the Newstar NTR-Q7UO code for Sharp tv model 29V-FL200
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Sep 29, 2016 | Sharp Televison & Video
Need code for a Carib rm 880e universal tv remote need to program my sharp tv
0190,0127,0172. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 10, 2015 | Sharp Televison & Video
I have a Sharp 32 inch tv and an GE Universal remote needing a code to set...yr of TV not known
1392,1330,1326. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 29, 2015 | GE Televison & Video
Can I use a rca universal remote on a sharp tv. If so I need help
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 19, 2014 | Televison & Video
Need the code for sharp tv its a ge 24993-v2 1145 remote
Look for the manual that came with the remote. In the manual you should find the various Codes used for different TV's. Each make (TV) has several codes to offer and if you are lucky, you may just select the correct code 1st time around. If not, try all the codes, one after the other until you get one to work.
Dec 19, 2013 | Televison & Video
Sharp tv password
Universal remote control setup codes to Sharp brand TVs are 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122 These codes may differ to different brands of remote controls. Given here is the codes to GE universal remote control codes to Sharp brand TVs. If you wish to get more, check the site linked here. http://electrohelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | Televison & Video
Need remote for sharp aquos LC42XD1E
Setup codes to Sharp brand TVs with universal remote control are 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122. Just buy a remote control, which has setup codes to Sharp TV. You can get this iformation from the attached specification sheet with each universal remote control If you wish to get more details to different other brand remote controls, check this link.
Feb 06, 2013 | Sharp Aquos LC42XD1E 42 in. LCD TV
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
Chunghop RM-133E universal remote
Chunghop 133E
TCL- 051, 053, 068,071,073,082, 083, 084, 085, 110, 111,144, 156
199, 209, 216, 243, 244, 245, 246, to 249
Panasonic- 020, 001, 002, 014, 015, 021, 022, 059, 066
SONY- 041, 049, 005, 094, 106, 148, 237, 238, 239, 240
JVC- 089, 161
Goldstar- 009, 019, 023, 024, 040, 043, 098, 140
Hope this helps!
diane
Jan 31, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
