Question about Ecoquest Fresh Air Air Purifier
Lamp replacement??? i tried replacing the burnt out purifier uv bulb in my ecoquest.  when i turned it back on, the message read "replace bulb".  and the light didnt turn on.  now what???  this unit sure has been a pain to maintain though it works great when it is running.  help ...
  • gk19704 May 11, 2010
    where is the bulb at?
    Can't find where the lamp goes.
I had this same problem, after putting the new lamp in and taking it back out several times, I realized that I hadn't twisted it into place hard enough. I felt like I was going to break the bulb, but after a very firm twist and a snap, it turned on and is now working perfectly.
Posted on Nov 15, 2008
Make sure the lamp is seated properly. Take it out, put it back in, turning it back and forth until it clicks. DO NOT TOUCH with your bare fingers.
May also need to replace the starter (the aluminum can at the rear of the unit).
Posted on Jan 31, 2008
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
Fresh Air Maachine by Ecoquest
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Jul 12, 2008 | Ecoquest Fresh Air Air Purifier
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
I have a "fresh air" and I'm receiving a message saying synair- G4 replace lamp. Does this mean only to replace UV lamp
This means that the UV lamp has stopped working. Since you need a good starter to make the lamp work, it make sense to replace both at the same time.
Feb 04, 2010 | Ecoquest Fresh Air Air Purifier
Replaced RCI Cell 2 times, light still doesn't come on
The U.V light is inside the RCI cell. If you replace the RCI, it has been ok. Please don't mind the screen display.
Oct 09, 2008 | Ecoquest Fresh Air Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Sep 25, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
402 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
