Question about Clavia Nord Stage 88 - Digital Stage Piano NS88
System crashed no buttons or knobs work just flashing lights display screen displays garbage
  • 3,741 Answers
Its the problem of internal control panel board.on the front of the unit.either the connection of wires internally is got loose or the panel is internally got short.you will have to check the fault before proceeding as it can be onlt\y wires getting cut in the front control panel board or the faulty control panel board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 11, 2009
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
1) Press the [UTIL] button.
2) Press the [PAGE DOWN] button until the 'Factory Set' screen appears. The message 'Factory Set' will begin flashing on the LCD.
3) Press the [SAVE/ENT] button. The LCD will display the message prompt, 'All data will be lost, Are You Sure?'.
4) Press the [SAVE/ENT] button again to complete the Factory Reset procedure.
Dec 31, 2017 | Yamaha Music
My MusicPad Pro Plus will not power up.
Probably your battery packs won't hold a charge any more. See my post here
Jan 03, 2014 | FreeHand Systems Freehand MusicPad Pro...
Lscreen problem
Look at the back of the keyboard,there is a small knob that controls the screen clarity,turn this to fix it,if that don't work,you need to get the screen replaced.
Feb 03, 2013 | Yamaha PSR-S500 Digital Keyboard
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
Hi , I wonder if you could shed some light on a problem my son has with his behringer pmh3000 amp. With the digital effects set to any number it constantly reverts to 1. Also when effects are turned on...
You say lights flash? There are a lot of LED's on the unit and there are displays. Depending on what you mean by "lights" sends us on a whole different path. Remeber the effects ADD to the noise as they add into the buss to the amps. You should have the Effect to MAIN knobs not too high... say 12 o'clock. Same for the effect send knobs for the channels. If all the LED's flash, better stop using the unit as there is a power supply problem and damage will occur.
Please read my tip on here about the hazard of Channel A output when using Speakon to 1/4 inch speaker cables or adapters. The SHELL or SLEEVE of channel A cable is the HOT one, NOT the tip so never let that shell touch or connect to ground. The effect window when first powered should display a zero, not one... If it displays 1 at first, unit needs to be taken for repair as there is a defect.
Connect ALL interconnected equipment to the same receptacle or power conditioner source. Pro's run extension cord back to mixer if they have other stuff on stage. The speaker cables should connect to NOTHING other than speakers... do NOT try to tap off the daisy chain outputs of speakers for anything other than speakers. Use balanced lines and isolating DI boxes to avoid ground loops. Make sure to only poower this from a grounded receptacle.
Apr 16, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
2442FX. When the mixer is switched on the numerical displays on the twin digital FX units flash and the FX units don't work.
The flashing means the FX hasn't been activated yet. Dial up the number you want THEN push DOWN on the knob to activate and the flashing stops and the FX takes effect.
Mar 29, 2011 | Behringer XENYX 2442FX Mixer
HELLO, I HAVE A BEHRINGER PMP 3000 MIXER, AND I CANT SEEM TO GET THE FX TO WORK EVEN THOUGH I FOLLOWED THE INSTRUCTIONS IN MANUAL, IME JUST WONDERING IF THERE IS SOMETHING IME OVERLOOKING? SCINCE I KNOW...
Do the following:
Set each of the FX mix knobs to 12 o'clock (halfway up to start)... I believe they are orange tops for each channel effects are desired for.
Next select the number of effect by rotating the selection knob. The display will flash.
Push DOWN on the selection knob to activate the selected effect number... the display will cease to flash. Note that you can mute the effects with a small button in the effect area and decimal point will come on showing effect, even though selected, is disabled. That small button can toggle the effects on and off.
Next, adjust the "FX to main knob" above the MAIN fader... set it to 12 o'clock to start with.
Note that there are two others that send the resultant same effect to stage monitors if used...
Now ADVANCE the FX (orange) fader to increase the input to the FX. You should start to hear the effects... SOME of the effects are subtle, so maybe choose a long delay one to get the hang of it... choose #3 for example...
The manual is NOT too clear how to use the effects and is confusing... they assume you have knowledge common to mixers... and new users don't.
I would recommend watching several YouTube videos about mixer setup... there are some good ones there !!! Most mixers have a lot in common and once you learn what is there, you can work most any of them... some of the new digital ones are a bit more confusing.
Feb 14, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
The bottons for my effects are not working
what doesn't work? the button itself, the efects selector knob, or the display? the more info. the better
- josh
Jan 13, 2011 | Pioneer DJM800 DJ Mixer (Warehouse...
The display on my Technics KN1200 keyboards is blank -I have not used it for some time but when I tried it Yesterday the display is blank -All the other Functions works well. please help Thanks Fritz
Check if there is a contrast setting knob or function. Often the contrast setting gets clobbered and then the display will be blank... worst thing if it is internal setting and you can't see the screen to change it... In that case do a factory reset on the unit. Usually this is holding down multiple buttons when turning power on.
Dec 29, 2010 | Music
Clavia Nord Stage 88 - Digital Stage Piano NS88 Logo
48 people viewed this question
Top Clavia Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Clavia Music Expert? Answer questions, earn points and help others
