Question about RIM BlackBerry Bold 9000 Smartphone
My blackerry bold 9000 will not ring. All
My blackerry bold 9000 will not ring. All profiles and settings are correct. It used to ring, but it has just stopped. It will vibrate, but no rings on e-mails or phone calls at all.
The volume is down when it rings and i cant hear it
On the right side there is a volume rocker you can use to adjust the volume. If that doesn't work you can change your profile settings
Go to the profile select menu, select Advanced and change the volume setting.
Jul 05, 2010 | RIM BlackBerry Bold 9000 Smartphone
CAN'T HEAR MY PHONE RING WHEN SOMEONE CALLS ME I HAVE TO PUT THE PROFILE ON VIBRATE
Each of your profiles can be set to different ring tones and different volumes, so whatever profile you have your phone set to, make sure you have it on a ring tone you can hear, and make sure the volume is turned up. Let me know if this doesn't work.
Jun 18, 2010 | RIM BlackBerry Bold 9000 Smartphone
My ringer won't ring
On the Profile okay it using the trickball and select LOUD. This would do the trick and you'll start getting the your phone to ring.
Cheers
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Volume problems
Go to your "Options" (Spanner icon)
Go to Profiles (ring tones)
Enter on Normal
Go to Ring Tone
Volume and with your track ball set to your preference
Sep 12, 2009 | RIM BlackBerry Bold 9000 Smartphone
My Tour Blackberry Phone won't ring
First, setup a custom Sound Profile with your own setting, name it anything you want, such as: "Mine!" Make the profile active and test it by calling yourself from a landline. All of the *very* simple instructions for setting up a custom "Sound Profile" are on support.blackberry.com - just search for model 9630 User Guide. - Very simple, only takes a few minutes to step-through the instructions. P.S. WHILE the Power is on.........Take the battery out for a few seconds and put it back in. This performs a Soft-Reset on the phone and does not delete or erase anything.
Sep 01, 2009 | RIM BlackBerry Bold 9000 Smartphone
By Blackberry Bold will not ring.
Did you go into the advanced settings for whichever profile you have it on?
If instead of chosing a profile you go to the bottom of the list and choose advanced it allows you to make sure that the individual settings haven't been changed within that profile.
Jun 22, 2009 | RIM BlackBerry Bold 9000 Smartphone
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bold 9000 ring and alert volume way too low, regardless of settings
Some of the ringtones in the Bold don't seem to be suited for "loud" profiles.
Try to edit your settings for the ringtone, making sure you pay attention to the correct settings.
To edit your ring settings
-go to your "profiles" screen -roll the ball to the bottom and select "advanced" -highlight the profile you want to edit -use your BB button to select "edit"
-choose the "phone" application -choose the setting you would like to edit (in holster or out of holster) -choose your volume setting from here.
This should solve your problem
Apr 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
229 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
