Question about Kicker ZX2500.1 Car Audio Amplifier
Kicker zx2500.1 problems
I was just wanting to know what was goin on with my amp. Out of no where one day it stopped working and started to make a horrible clicking noise. Does anyone have any suggestions?
    Novelist:
  • 92 Answers
DISCONNECT THE RCA INPUTS AND SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO LOAD CONDITION. IF THE SYMPTOMS ARE THE SAME, MAKE SURE THAT ALL POWER CONNECTIONS ARE GOOD AND IF POSSIBLE, MEASURE THE VOLTAGE AT THE REMOTE TERMINAL TO GROUND. IT SHOULD BE APPROX. 12 VOLTS. IF LESS THAN 11 VOLTS, YOU MAY HAVE A PROBLEM WITH THE REMOTE OUTPUT FROM THE RADIO. THIS IS RARE THOUGH. IF YOU CANNOT TEST THE REMOTE INPUT VOLTAGE, THEN DISCONNECT IT FROM THE RADIO AND PUT A TEMPORARY JUMPER FROM THE POSITIVE POWER TERMINAL AND THE REMOTE LEAD. THIS WILL FORCE ANY AMPLIFIER TO TURN ON. IF YOU STILL HAVE THE SYMPTOMS OF INTERNAL CLICKING, THIS IS THE OUTPUT RELAY AND IT IS TRIPPING AS A MEANS OF PROTECTION. AT THIS POINT THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE....V
Posted on Jan 06, 2010
Rockford Fosgate P3002 stopped working
push down and up on your subs and see if they make a starching noise, if they do then they are blown. take a test light to the amp, on the power and the remote and see if it lights up. if it does then turn the amp down and with a small speaker plug it in to the speaker outs on the amp and see if it plays if not then your amp is bad.
Nov 26, 2013 | Rockford Fosgate Punch P3002 Car Audio...
How can you tell if your starter is goin bad
A bad starter will kill a battery real quick. If you can find a DC amp-meter compare it to factory specs, or similar car starters. A bad starter will make a grinding noise, or give false tries where the starter spins free without engaging the motor. Of course, a bad starter will not spin at all, just make sure the relay is working.
Mar 11, 2012 | 1993 Oldsmobile Cutlass Ciera
I have a HP Photosmart C4780 all in one printer and when I turn it on, as well as before I go to print something, the printer makes a horrible, loud clicking sound. I have cleaned out the inside and...
There may be nothing you can do about it. A lot of the HP printers make a lot of noise as they start up or prepare to print. Has your printer always made this noise or did it just start?
Jul 26, 2011 | HP Photosmart C7280 Laser Printer
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
Subs go in and out all other speakers work and kicker amp still has green light on
unplug ur acr wires if it stops plug the red one in an wait to see if it does it , if not then un plug it an plug the white one in an wait , if one of the in put on the amp is gone then it will let u know what one ,say the white acr wire made the noise when u pluged it in ,unplug it from the white acr input an put it in the red acr input if it stopped makeing nosie then its ur acr input on the amp . but if not then it could be in ur acr wires or cd deck , if u know its not the deck or its new then make shore ur ground is good an the power wire is almost the same size wires because the amp will draw more power if power wire is bigger then ground an if grounds bigger then the power its not goin to get enuff power , i hope this was helpful an please votes for me
Jul 11, 2011 | Kicker KX250.2 2 Channel Car Amplifier...
My tribute started making a clicking/rattling noise near the belt that has gotten louder within a day. It is not the oil. Would you have an idea of what it could be?
Drive belt needed to be replaced on mine... Mazda dealership told me that the manufacturer knows that the drive belt is not strong enough... when I ran the air conditioner it was horrible sounding!!! It took the dealership repair 2 days to figure it out!
May 21, 2010 | 2008 Mazda Tribute
Kicker zx650.4 amp turned off and on
could be a couple of things going wrong. could have overheated and shutdown to protect it. could have hand to many incoming wattage/voltage from your head unit and shutdown. could be that the ohms rating on your speakers is to low or that the speakers could have heated up and bumped the guilds and caused it to shutdown. don't know if you know how ohms works. but here is an exp. if you have and have that is rated at 4 ohm stable and that is the lostes ohm recomened for it. and you have two 4 ohm rated subs. you can run them and run them with no problem as long as you don't bridge them. run them off of the same port on the amp. when bridging them it devides the ohms in half. so 2 4ohms would become 2 ohm. 2 8ohm would become 4 ohm etc. if you are running 4 speakers in pair that are 8 ohm each the total together would be 2ohm. hope this helps. try to duplacate the conditions that was going the other day when it shut down same bass settings same song etc and see if it happens again if so try unhooking one of the speakers and try it again if it don't do it it was overloading it if it was overloading and you know its right ohms etc. send it in sorry this is so long.
May 01, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Kicker ZX2500.1 Car Audio Amplifier Logo
212 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
