Question about Dynex DX-LCD37 TV
How to restore Dynex LCD TV back to factory
I am trying to reset my television back to its factory settings because I have a strange green tint to it.
Http://www.avsforum.com/avs-vb/archive/index.php/t-1151994.html
this site has free directions to reset it
Posted on Apr 22, 2011
Have red tint in picture
It sounds like the color settings are out of whack, try going to the tv settings and reset them back to default. Then try changing the Red green blue values (RGB) in the color settings, simply lowering the red value might do the trick
Apr 10, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Red tint on the screen an picture
Make sure the signal cable for the input you are using is tight. Possibly try a different cable. Especially if you are using the Red Green Blue component cables. Make sure the issue is across all inputs. If so, try adjusting settings for tint. if that doesn't help you may need to replace the TV.
Apr 09, 2014 | Dynex DX-L32-10A 32" LCD HDTV
Sound at 100% will not go down Dynex high def
Try to power cycle the TV: power it off and unplug it for a few minutes. Plug it back in and power it back in. Restore any setting changes back to factory defaults. You can also try and reset the remote by pressing all the buttons on it at the same time. If these tips don't help, then I would recommend bringing the TV, along with the receipt, back to the place of purchase to pursue repair/replacement options.
Nov 05, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I have a dynex 55 inch tv it turns and runs for a whike and then shuts off I can not get it to turn back on until I unplug it and dose the same thing over again can any one help.
I would recommend doing power cycling your TV. Turn it off, unplug it and leave unplugged for a few minutes, then plug it in and power it on. If this doesn't fix the issue, then I would also ensure settings are back to factory defaults.
Press Menu
Press Left or Right to select Setup, then press Down to open the Setup menu.
Press Up or Down to select Restore Defaults, then press Right or Enter.
When a message asks if you want to restore factory settings, select Yes to restore the settings, or select No, to exit without restoring settings.
Oct 23, 2013 | Dynex DX-LCD32-09 LCD TV
Volume control suddenly only adjusts to barely audible
Try pressing all the buttons on the remote simultaneously-this will reset the remote & then program the remote to the TV. You can also try and power cycle the TV by unplugging the TV from the wall for a minute, then plugging it back in & power it on. Restore any changed system settings to factory defaults.
Sep 25, 2013 | Dynex DX-LCD32-09 LCD TV
Philips 26PF5521d LCD TV turns on screen lights for a few seconds then turns off leaving green led flashing Any help apreciated
Tries unplug,replug the tv back like an hour later.Now,the tv is resetting itself back to the factory setting.The tv now,should work again.Not,than the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 27, 2010 | Dynex DX-LCD37 TV
Green tint on entire screen of Sony KDS-55A2020.
When I was reading the instructions for this tv, It was saying if the projection bulb is reaching the end of its life you will get strange color changes. You can also reset your settings in the setting section. Go to your menu and go to settings and them picture. You can reset your picture to factory settings in this menu. Now you can reset in different modes also. You have to be in these modes to set factory settings. These are Vivid, Standard and Custom. Take a look. You can go to sony and it tells you haw to do all of this. You punch in your TV type and you can go into the instructions. I learned how to change my projection lamp.
Sep 19, 2009 | Sony KDS-55A2020 55" Television
My sharp aquos 32' LCD has a heavy green tint to it. I tried reseting the settings back to factory settings, but it didn't help.
My sharp tv also had a green tint and resetting to facotry setting did not work, what finally worked is making sure that all cables were inserted all the way into the tv and receiver. Someone else advised this for another Tv and it worked on my sharp so it is worth a try.
Aug 19, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Dynex DX-LCD37 TV Logo
3,249 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
