Question about Sony Televison & Video
I have my tv KDS-R60XBR1 projection tv from sony. the problem is the tv is not turn on. led red flashing and turn off. no picture and sound. I replace the lamp, but it still doesn't work. Please give me some advice
    Problem Solver:
  • 18 Answers
WELL IF YOU JUST RECENTLY REPLACED THE LAMP AND THE TV STILL WONT TURN ON THE PROBLEM IS GOING TO BE COMING FROM THE BALLAST BOARD IT LOOKS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP SO IT COULD TURN THIS IS THE POWER SOURCE FOR THE LAMP IF THIS PART IS NOT OK THEN THE LAMP WILL NEVER TURN ON
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Posted on Dec 11, 2009
SOURCE:
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1 Projection TV and it stopped working last night... We are getting FIVE red blinks! What does that mean? Fans, bulbs.... ??? Thank you in advance for any...
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Jan 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Turned off while watching, won't turn back on.
The TV is in "protect " mode,which means that it is shut down because of an internal fault condition. - unfortunately you need a technician to investigate the problem . THis is not a job for a hanyman. Sorry ..
Sep 13, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
