Question about Performance Teknique Car Audio & Video
I have a preformance teknique icbm-7355 i need to know what to hook the bluetooth ant wire to
  • 3,230 Answers
Well there is a USB port where you need to plug the bluetooth device, and you can use the cable comes with your receiver.
Good Luck!!
Thanks
Posted on Dec 11, 2009
SOURCE:
Installation-wiring
Performance Teknique might be able to supply a manual and/or wiring instructions.
Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
I needed the conector for performance teknique icbm 9778
i have the whole stero but if you want to we can talk ...mine works perfectly but the monitor doesn't flip up cuz i rip the wire that's connected between the stero and monitor..call me at 562 480 7084 thanks
Jan 01, 2013 | Performance Teknique ICBM-9778
Hey I just recently buy a performance teknique
good luck finding one, check ebay, or call Teknique directly.
Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
Keeps on diagnostic after i turned it on and had it completely wired what should be the problem
have you checked the power ant wire? usualy oarnge this needs to be hooked to a power source that is not on when the power of your vehicle is not on (usualy a fuse block)
May 11, 2009 | Performance Teknique ICBM-895 Car Audio...
Wiring 12" icmb-5612 preformance teknique subwoofer
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Performance Teknique ICBM-771.
probly your ground isnt connected right or yor spaekers are probly not connected right recheck and check if the ohmms set on your speakers your amp probly ant handle it
Jun 28, 2008 | Performance Teknique ICBM-771 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Car Audio & Video Logo
54 people viewed this question
Top Performance Teknique Car Audio & Video Experts
Mike Duncan
Mike Duncan
Pierre Laplante
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
