Question about Memorex MVD2022 DVD Player
I have a mvd 4544 dvd combo hooked it up to my new vizio tv and now i get a split screen with a yellow pscan box in the middle.
  • jamesw2247 Dec 11, 2009
    I don't know if its set up as progreesive scan or not worked fine on old tv i have it hooked up to av1 on tv i suspect its a setting thats screwed up on the player but no manual. I'd appreciate any help you can think of. Thanks Jim
    Sorry i figured it out the switch in the back got moved to turn the progresive on some how now everything is good thanks.
  • 4,472 Answers
Do you have the dvd player set up as progressive scan? Most likely this is a settings issue. How are you connecting the dvd player to the tv as in what type of connection? Once I have more information I can assist you further.
Thank you,
Lee
Posted on Dec 11, 2009
  • Lee A.
    Lee A. Dec 11, 2009
    Ok,
    And how are you connecting the dvd player to the tv again? You can view the manual online provided by fixya at this link.
    http://www.fixya.com/support/p234926-mem...
    or download the pdf here from this link:
    http://www.nodevice.com/user_manual/memo...
    If you refer to page 11/35 of the pdf. Check the progressive switch on the back of the unit. Let me know what is selected.
    Hope this helps if you need further assistance let me know.
    Thank you,
    Lee
  • Lee A.
    Lee A. Dec 11, 2009
    That is what I thought it was. Glad I could help and glad it was an easy fix. Please take a moment to accept/rate my solution accordingly.
    Thanks for using Fixya and have a great day,
    Lee
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
Thanks.
May 28, 2010 | Memorex MVD-2045 DVD Player
When i load a DVD, I get a split screen and a large PSCAN!
Probably fix it with the remote. Look up progressive scan in your manual, and turn it off.
Apr 29, 2010 | Sceptre X240BV-FHD LCD TV
PSCAN warning and screen is split in two
hotpoint first edition hvl211 has 3 flashing lights how do u stop this is there a reset you can do
Jan 05, 2010 | Acoustic Solutions Audio Players &...
The dvd player displays a big yellow box in the middle of the screen with PSCAN with an exclamation point above it. Also the screen is showing the right side with a wide split between them. This is the...
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Nov 03, 2009 | Memorex MVD2042 DVD Player
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
PSCAN! Message
your picture and picture setting or may have FLEX CONVERTER PROBLEM need to call local tv shop
Feb 06, 2008 | Hitachi 43FDX01B TV
Mvd-4544
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video (yellow) RCA jack and S-VIDEO jack.  If you are using the Component jacks, the DVD side will work but the VCR will not.  This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Oct 22, 2007 | Televison & Video
Memorex MVD2022 DVD Player Logo
176 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
