Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Frigidaire Gallery Range m#FEF389CFBK. The heat
Frigidaire Gallery Range model# FEF389CFBK. The heat element was burning like a sparkler. Is a new element all that is needed?
  • Frigidaire Master
  • 2,605 Answers
Hi, If I was being called out to look at your range and you described to me what you said in your post, I would definetly bring an element. I suugest you tell that to your service person or purchase a new element. That is quite often the way the element's burn out, just as you described...a sparkler. Hope that help's. Good luck and thank's for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
Oven is over heating to set temp
Well if that is really happening you would need to make sure that the temperature gauge is working properly
Jul 31, 2016 | Frigidaire Gallery 30" Self-Cleaning...
Gallery series Frigidaire gas oven not heating up correctly
Hello Hilda, thank you for your post!
There could be a number of
any one of several underlying causes in why the oven is experiencing this
particular issue:
·Convection
heating element
·Thermal cutout
·Thermal oven
sensor
·EOC
(electronic oven control)
·Ignitor,
·Bake or broil
element
·All wired
connections
·Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat.
The parts above will need to be assessed for further evaluation by a technician since it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Aug 29, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven heats too slowly, and temp on thermostat does not match real temp in oven
Hello Henk Rietveld - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 09, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
356 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
