Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Can't see the flash drive, I put in one computer, pull it out then put in another computer, the light would come on but it was not see by the computer. The light normally goes light to bright but it is just bright now.
  • Colin May 11, 2010
    Can you see it in both PCs????
    Brigadier General:
  • 10,406 Answers
Do *ANY* USB memory-sticks work in *ANY* USB-ports on the second computer?
Posted on Dec 11, 2009
Reassemble flash drive?
Sure, just put a healthy dose of super glue or hot glue from a glue gun all over the internals and jam it back in. It wont hurt it.
Feb 01, 2013 | PNY Electronics - Others
Can't get DVD ffrom computer drive
Let's start with the obvious...Did you press the eject/ pull-in button on the drive when the computer was on? Do you have power to the drive when the computer is on (does the light on the front of the drive light up when you first boot up your computer?) Is the front of the drive flush against the computer and not sticking out a little? If the answers to all of the questions is yes, then you have a jammed drive. By the way, does it make any noises when you first turn on the computer or does the light on t only flash with no noises? If you have confirmed everything, now is time to get messy! Turn off the power to your computer and pull off the panal that exposes the motherboard and all of the devices inside. Take the connectors off the drive in question and unscrew the mounting screws. Slide the drive out and put it on the desk or table. Manually pull out the drawer where the CD is and take it out....buy a NEW drive and toss the old one!
Jan 02, 2013 | Computers & Internet
My son set up my 8GB flash drive to automatically download "My Documents" as soon as I put in my password. What do I do if I have a computer crash and want to download my documents to a new hard drive?
when you will have a computer crash(hopely not) and reinstal(or you pull out the flash drive) when you download something it will pop up a window where you can select to folder where to save.
Jan 04, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a 4gb cruzer flash drive and its not working
Okay. Try putting it in on the back of your computer and tell me if it lights up at all, even if it flashes once.
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Mar 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My trany doesnt chge gears 1990 acura ledgend atm
I just ran into the same problem. Today my mechanic showed me 2 computers, one under the rug under the glove box on the floor. Lift rug and turn key on, not to turn car on but to just turn radio on, and see if a red light flashes on this computer. It should flash once when you turn the key on. If it flsahes more than that one time, count the number of times it flashes and then light will stop flashing and start flashing again. Count it thru a few of those times to make sure you have the number of times it flashes right. If it flashes more than once, this is called a code. Having a code means there is something wrong with car, your mechanic should be able to tell you what the code means. Mine was flashing 2X, so the code was 2. My mechanic pulled the corresponding fuse for this code, and held the fuse out for 10 seconds, and then put it back in, this reset the computer to no codes. He told me to drivew it home and then shut car off and then turn key on again and see again if any code was flashing. When I got home, no code was flashing on this computer. Good news, resetting it by pulling the fuse fixed whatever that computer was doing.
Secondly, he checked another computer under my pass. seat, to do this you need to turn key on, (do not start car), and you have to view this from the BACK seat, it should flash a red light once and then no flashing. Well, mine flashed 15X, so was a code 15. He pulled the corresponding fuse, held it out for 10 sec. and put fuse back in. It then showed no flashing except for the one time it is supposed to flash when you turn key on. He told me to check it once home, I did, and the 15 flashes (code 15) is back and what this means is I need a speed control sensor. And he said it definitely does whack out the tranny. So all I need is a speed control sensor, not a transmission replacement! Try this and see if yours gives you codes and if so, have mechanic pull the correct fuses and hold them out for 10 seconds and then put back in. Then drive your car for awhile, and recheck the computer modules again for any flashing lights (codes.) You may just need a speed control sensor!!
Oct 08, 2008 | 1990 Acura Legend
I have a 1990 Acura Legend. The transmission seems like its slipping. The car will drive for about 5 minutes and then when i step on the gas the car wont drive anymore. I have to pull the car over and...
I am very excited because I have the same problem and thought it was transmission but went to my mechanic today and he found that some computers were giving codes on my car. One computer module is under Right Passenger seat, turn key on but do not start car and read how many times that light flashes, then ask mechanice to tell you what the code means. In my case what is causing the tranny to slip is the need for a new speed sensor control module. So, you may just need one of those too instead of a new tranny. !!!! Since my Legend was flashing a code 15, my mechanic pulled the fuse that you are supposed to pull when this 15 code comes up and hold it out of fuel box for 10 seconds and then put it back in. This reset the computer and then it showed no code, (no flashing light.) He told me to drive it for awhile and then check again to see if a code was flashing. If nothing flashes then you are OK. If it does flash, count number of times it flashes and tell the mechanic. If the light flashes, it means it is a "code". If it flashes 15 times it is a speed control sensor messing up the transmission capability and just needs the speed control sensor replaced!!
He also checked a computer under the rug of the passenger side dashboard under the glove box. It was flashing a 2, (2X). He pulled the fuse that corresponds to that and held it out for 10 seconds to reset it, and now it does not flash, ie shows no code, so that is fine. But check those 2 computers on your Acura to see if it is giving you flashing light in either of them, and if so, count how many times it flashes, and then you will know if it is really the transmission.
My car runs a HECK of a lot better now that he reset the codes. I think something got "off" when my alternator was replaced and they had to be reset.
I am thrilled I won't have to replace transmission!!
Jul 26, 2008 | 1990 Acura Legend
Flash drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. When it opens right click on your mouse over the document you need and click send to: desktop, ect. Let me know what happens.
cynthia
Jan 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flashing led light on my hard drive
well the best thing i figured out to do was to purchase a new case. i think the case burned up. i pulled the hard drive out and hooked it up to another drive so to see if it would work. the drive works just fine in the other device, so i ordered another case.
Nov 06, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
111 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
