Question about Mitsubishi WD62627 62" HDTV
Will not display 1080p from a Sony ps3??
Blu-ray discs only show in 1080i??? Why not 1080p?
  • Anonymous Feb 23, 2008
    I have the samsung blu ray and when I tried to output to TV 1080p it played sound not the picture
  • rkguz Feb 24, 2008
    I also have the mitsubishi wd-62627 and samsung bd-p1200 ,when trying to plat 1080p the sreen is blue and all you here is audio.How can i get the t.v to play 1080p?
  • 3 Answers
Connect your PS3 through the HDMI 2 port on the TV and as a PC under the tv settings. Then auto setup the tv on the PS3 and it will now see it as 1080P. It will give you some error message whenever the PS3 is first turned on but it will work. Hope this helps everyone.
Ryan
Posted on Jan 21, 2008
6ya staff
SOURCE:
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I want ot change my LG television Model 47LH40 to 1080p using my LG remote
1080p video resolution can only be achieved by a Blu-ray Disc. Satellite TV, broadcast TV, cable TV do not actually send out 1080p resolution. So unless you are using a Blu-ray movie, you will not be viewing 1080p. Your HDTV has a NATIVE screen resolution and the TV will SCALE all incoming video to its native resolution. Most people cannot tell the difference between 720p and 1080i. 1080p signal sources are slightly sharper. But if you have a HDTV that is 1080p capable and you give it a 1080p source (Blu-ray Disc) and use a HDMI cable to connect, you will get 1080p, you do not have to change the HDTV as it will automatically display 1080p.
Mar 25, 2011 | LG Televison & Video
Won't play 1080p discs?
From this problem's description I have to assume that either the blu ray player will not play blu rays or the blu ray player will play blu rays but only in 1080i/720p or that you want to know if this blu ray player supports the 1080p resolution.
If the blu ray player is not playing blu rays then you update the firmware and try multiple purchased discs to make sure nothing is wrong with the ones you have been trying. If blu rays that played once will no longer play, then you will need to reset the blu ray player from its menu and possibly by holding down the power button on the front of the unit until the word reset displays on the unit before trying to play the disc again.
If the television is not showing 1080p make sure you are connected with an hdmi cable and that it is the right version hdmi cable for this blu ray player and for your television. Make sure you have chosen 1080p as the resolution to display in the blu ray player's menu. If all of that has been done and 1080p will still not display then it is a case of incompatibility between manufacturers--Sharp and whatever the television is. It would display in 1080p on a Sharp television and most likely on a Samsung and Sony as well. With other brands and even some models of the aforementioned brands (except for Sharp) its a toss up.
Mar 05, 2011 | Sharp Aquos BDHP50 Blu-Ray Player
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
I have a sony bdps360 i need to reset the res from 1080p to 1080i i need HELP
You can select the “HDMI Resolution” of the Blu-ray Player is set to “Auto,” “1080i,” or “1080p” in the “Video Settings” setup. You can refer the page # 43 of the Manual of the Blu-ray Player.
Jan 16, 2010 | Sony BDP-S360 DVD Player
I need to unlock blue-ray sony bdp-s360
tv repeating hdmi signal out of range did a bad choice 1080p instead of 1080i how fix the problem? thank you
Nov 20, 2009 | Sony BDP-S300 Blu-Ray Disc Player
PS3 and Sony Bravia
one of your lasers in PS3 is probably bad
Jul 27, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi WD62627 62" HDTV Logo
674 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
