Question about Fuji FinePix S700 Digital Camera
How do i fix the zoom, i accidently dropped it and it will not zoom in anymore
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 11, 2009
My digital camera is Samsung Galaxy, Model no is EK-GC100. Last week it fell down and the zoom lens has some problem. It can't zoom in or zoom out anymore, and it appeared the message: "there was a problem...
is there any sign of scratches to show its been dropped? if not samsung offer a 2 year guarentee, take it to any well known phone shop such as carphone warehouse (with proof of date bought) and they will send it away. be warned they will always tell you that samsung will try to fix it but really samsung will just issue you with a referbished one and then they will fix your one in their own time.
Oct 09, 2013 | Cameras
Problem with zoom and touchscreen
there is two problum in your camera one is lcd defective & other is lsv assy so please go to youe nearst sony service centre & fix these two problums
Apr 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
LENS NOT WORKING
Sorry, but there's no DIY fix for the lens problem. You can send to Kodak for repair or take it to a local shop -- but get an estimate first. In the Kodak price range you may be better off cost-wise with a replacement than a repair.
Dec 05, 2009 | Kodak EasyShare M853 Digital Camera
My Sony handycam optical zoom stopped working
needs to be check by an authorized SONY DEALER.
theres a ribbon connector that needs to be replaced ,or If you drop the camcorder by accident it could be that the ribbon is misplaced, hope it helps , AJ
Oct 23, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
I dropped it and it says zoom error
Sounds like the power zoom assembly (motor, gears, etc), has jammed due to the drop. That and possible electronic problems on the controller board or possibly the zoom switch itself suffered damage in the drop also. Try working the zoom switch rapidly , back and forth a few times and see if it frees up. May be a candidate for the repair shop. Sorry for your accident.
Jul 14, 2009 | Fuji FinePix S700 Digital Camera
HOW CAN I FIX MY LENS ON MY FUJIFILM FINEPIX J15?
The only thing i can think you could do is bring it to a repair shop they will repair it for free if there is warranty on it.. hope this helps
May 20, 2009 | Fuji Rod Repair Kit
My mouse is a wireless mouse and i dropped it accidently once. Right after the fall,it is not working anymore. Can i actually fix it?
It is possible that the battery popped out when it was dropped. It is possible that the battery got put back in wrong. Open the battery case and remove the battery. Then be sure to replace the battery with the positive end going in the right direction.
That should fix it for u.
Please rate my answer as a fixya thanks
Mar 05, 2009 | Impression Products Impression M1 Wireless...
Zoom Problem
The zoom are lock due to sudden dropped , the moving parts of the zoom dislocate or broken, the zoom malfunction,you try visit some camera juck shop or repair shop same brand to replce broken parts.
Dec 23, 2007 | Olympus FE-280 Digital Camera
Zoom Error
Lens unit has to come out to see whether the problem can be sorted out without spares going in. But unfortunately you have to go from the back on this model which means disconnecting and removing all 3 pc boards and the LCD screen and then loosening the lens mounting to slide the lens out from the back. You may have to dismantle the free lens further once it is out to see exactly what the damage is ( if any ).
Sep 07, 2007 | Fuji FinePix S7000 Digital Camera
Concerning fuji digital camera F650- how to fix it ..
These things are not servicable Simply replace it .
Jun 29, 2007 | Fuji FinePix F650 Digital Camera
Fuji FinePix S700 Digital Camera Logo
85 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
