Question about Magic Chef MCWC16MCG Wine Cooler
Brushless dc fan model rdm8015b shows E4. I have taken the unit apart and need the fan hoping I can put it together.
  • silverbayny May 11, 2010
    We found an address that carried the fan and ordered it. Please take me off your e-mail list. Thank you
Model HSS25GFTA, replaced control board and unit is working, the fan in bottom right of unit has not come on. Blades are not free spinning but are not frozen. Have checked all electrical connections by...
some fans in ref are dc volts some are ac volts.
send whole model # for proper diagnostics.
either fan is bad or your not getting power to it.
main computer board or fan poss. broken wire
Mar 06, 2015 | Hotpoint Refrigerators
Noisy fans on a desk-top pc Model Acer Veriton 1000. Besides replacement for new fans, can brushless fans be serviced or lubricated?
The Veriton 1000 I have has 50mm fans (length and width). 80mm are the wrong size. They are 15mm thick, 12V, 0.2A. For some reason, these seem to be more expensive than many other fans.
Jul 13, 2012 | Computers & Internet
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Need a fan for an Sony SXRD model KDS R50XBR1 Sony TV
ANDREW ELECTRONICS 1-800-274-4666 SONY M#8-835-860-31 MOTOR DCSFF21C/C-N $22.31
Feb 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Need DVR Surveillance Computer Fan
Any 8cm or fan listed as an 80 should work in your system. Just make sure you use one that has the same # of pins as the one you are replacing. Here is a link that should help: http://www.comparestoreprices.co.uk/computer-parts/akasa-internal-system-fan-8cm-3pin-dfs802512m.asp
Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Computers & Internet
Need a new DC brushless fan
www.farnell.com is available in UK.
Dec 31, 2007 | LG RH177 DVD Recorder/HDD Recorder
Magic Chef MCWC16MCG Wine Cooler Logo
476 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
