Question about Vizio SV421XVT 42 in. LCD TV
TruSound feature does not work
I just purchased the Vizio SV421XVT TV and noticed that the audio varies greatly from channel to channel as well as from a program to commercial. This problem seems to be worse with the TruSound feature turned on. With the TruSound feature off the audio works just like our crappy old TV that does not have any sort of sound level regulation.I have contacted Vizio about this problem but no joy yet. My TV is currently connected to a DishNet 522 DVR as the secondary TV, this means that the connection to the TV is via a coax cable to the TV's CATV port. Vizio support asked me to try another type of connection such as Component inputs or HDMI but that won't be possible for another week or two. I also connected a Sony Blu Ray DVD player to the HDMI port and noticed some sound level inconsistencies there as well but at the time I attributed this to the movie that I was watching.
I'm not sure if Vizio has a problem with their TruSound feature or if I just happen to have a lemon...
Thanks in advance for any assistance that you can provide,
Tom
What size screws hold the back cover of a Vizio sv421xvt tv? I am not talking about the screws for the stand.
If you wish to get some details; check the site linked here. Pull up older posts.
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Aug 06, 2016 | Vizio SV421XVT 42 in. LCD TV
Two vizio TV's with issues
Take them to a TV repair centre as they are complex to repair. You may find that your homeowner insurance will pay for the repairs if you can demonstrate that it was a power surge that damage them.
Feb 29, 2016 | Vizio SV421XVT 42 in. LCD TV
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
42" Vizio 240Hz SV421XVT no hdmi video or audio
Possible bad source, bad cable or connection was made with units powered up which HDMI does not like.
First thing to try in this case is to remove power from set and whatever unit is connected via HDMI and disconnect the cable itself.
Wait for several minutes, connect HDMI again and THEN return power to the units that were removed from power, this cannot hurt and may help or correct this issue.
Failing this try if possible to connect using component connections.
Dec 10, 2012 | Vizio SV421XVT 42 in. LCD TV
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
My Vizio 42" LCD SV421XVT
U getting a non respones from ur remote or the manual side panel tv controls buttons wright.U already tries resetting it back to factory setting.But the problems still the same.Yes,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 11, 2010 | Vizio 42 in. LCD TV
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
No audio on some hd channes
Try pressing the MTS button on your remote while on the channel that does not have audio and select stereo. Most likely this will be set to SAP (secondary audio programming) and there is no SAP programming on that show. This is not something that could be avoided. It was during the channel scan, it locked in the SAP audio broadcasts for some reason.
Apr 03, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vizio SV421XVT 42 in. LCD TV Logo
170 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
