Question about Sunbeam 4211 Iron
Iron leaks from place where you add water - Sunbeam 4211 Iron
  • 96 Answers
It is cracked you should get a new one
Posted on Dec 13, 2009
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Tip
My Steam Iron is Leaking Water
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
My iron is leaking water. Can it be repaired? I picked it up off the ironing board today and it was sitting in a puddle of water. It continued to pour out the bottom. Is this fixable?
I have had several do this after many many years of use. I did not find a fix but ended up buying a new model. If you do not need to use the steam function, you can still use it. Might want to use a spray bottle with water to add the steam the old fashion way.
Jan 27, 2014 | Irons
Breville VIN 214 iron leaking - can anyone help please
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
  1. Unplug the iron.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 14, 2012 | Irons
Water leaking from iron can you answer me third time ive asked now
see this steps and fix it. God bless you
  1. Unplug the iron.
Oct 15, 2012 | Frigidaire Fcl212/H 2200W Steam Spray Iron...
Leaking iron
Here is a tip that will help tou figure out your problem...
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 24, 2010 | Rowenta DZ1900 Iron
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Rowenta Professional DM890 Iron with Auto...
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Sunbeam 4211 Iron Logo
29 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
