When turning on the hl-s5679w the power lights come on and then start blinking.....tv makes sound like should be coming on(the click) but no picture and no sound....How can i test this to find the problem? 816-606-6257 thanks
i hope someone will be reading this cause all my lights are flashing how do i solve this?i hope someone will be reading this cause all my lights are flashing how do i solve this?
You can't post conmments that contain an email address.
Sounds like T'Con fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Check the plugs in the power supply and make sure they are all in the right place. It wouldn't be the dmd ic or light engine. It would be the digital board.
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Their is no more you can do. You need a professional. Stop using the TV until it is repaired. Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc Milwaukee, Wisconsin 53405 (414) 762-8600 Established 1974
capacitors.
