Question about Dryers
Rear Drum replacement - White Knight tumble dryer model 38AW
How do I replace the rear drum bearing for this model should a spear bearing be still obtainable? I have searched the Internet for this kit but with no results at the moment.
    Scholar:
  • 84 Answers
Go with the info, and if possible the old bearing--- to the appliance parts store and they will likely help you!!!
Posted on Dec 15, 2009
Can anyone help me plz, i have a 37AW white knight dryer,my partner slammed the door too hard and the dryer hasn't worked since, has anyone got any ideas how to fix it, or tell me what to look for?
Probably broken the door switch which stops the drum when the door is opened. It may even just be the nylon strike pin that presses the switch.
White Knight 37AW Tumble Dryer Spares ' White Knight Spares
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw/catalogue.pl?path...ref...
White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 37 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Spring For Door Latch.
White Knight 37AW Tumble Dryer Spares - WhiteKnight-Spares, Parts ...
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw.../catalogue.pl?path... White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 36 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Door Window - Clear.
White Knight 37AW Tumble Dryer Parts ' Partmaster
https://www.partmaster.co.uk/tumble-dryer/37aw.../catalogue.pl?...whiteknight... White Knight Tumble Dryer parts - repair your White Knight Tumble Dryer with a ... White Knight 37AW Switch Strike ... White Knight 37AW Spring For Door Latch.
37aw white knight dryer door switch Google Search
Jun 06, 2018 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
White knight
The replacement belt could have been installed incorrectly.
Nov 03, 2013 | Washing Machines
I can get the back of my white knight 38AW tumble dryer
try lifting the top of the dryer it usually pops up in the front then you will see the drum and the belt
Sep 27, 2012 | Abbaka White Knight 38AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
Cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 01, 2009 | Dryers
Dryers Logo
387 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
