Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
My dishwasher ran for 4 hours last night. When we realized that, we opened it and it was still soapy. Is it likely that I need to replace the timer?
My dishwasher will not come out of the wash cycle. It is flashing HO on the display. I've not use it but a few times over several yrs. has something gone bad?
Posted on Jan 13, 2010
  • 57 Answers
If the unit is not heating, it will run waiting for temp to be achieved. Check that there is a cut out stat on the heater. Reset this by pressing it. If not, check that the thermostats and or heater are okay.
Posted on Dec 11, 2009
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
We have a Kenmore electric dryer, and the timer no longer works. Last night it ran for six hours straight! Help! Thanks, Valerie rvgreen1@juno.com
The timer/control has gone bad and needs to be replaced...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 23, 2010 | Dryers
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Will not quit running on wash cycle for over 8 hours. Water soapy and hot.
Hard to help much without you posting the manufacturer and model number but if your dishwasher is more than a few years old and it has a mechanical dial , I would suspect that dial / timer has failed and needs to be replaced.
Please post back here what you find, OK?
Good Luck!
May 03, 2009 | Dishwashers
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore dishwasher
could be eithe depending on which one u have model and make helps
Oct 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
504 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Oloyede Monsuru
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
