Plug in usb and power cords and control panel
Setting up a used printer to my computer system. I plugged in the usb and power cords and control panel flashes. No software installed yet.
  • 8,404 Answers
Install the software ...
Standard process for installing USB stuff is install the software and only plug in the device when the wizard tells you to do so.
thanks for your interest in FixYa.com
please vote
thanks
a
Posted on Dec 11, 2009
Printer will not scan to computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/guXLhl. Select your operating system, download and execute the file.
Mar 08, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
USB PORTS
yes, disconnect power cord from computer and printer for ten minutes then connect it back
Mar 27, 2008 | HP LaserJet 3055 All-In-One Printer
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
Computer won't detect printer
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
The compuer is not connected
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Lexmark 2600
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
Jan 11, 2012 | Lexmark Office Equipment & Supplies
How do i get my Lexmark X2350 Printer to send e-mail? I scan my documents, but the new e-mail box does not appear after the scan like its suppose to.
Make sure that your default email program is correctly set on your computer.
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document to verify that the problem is fixed.
Nov 08, 2011 | Lexmark X2350 All-In-One InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
I try to print & my PC print que says "printing" but it also say the printer is offline. How do I get it back on line?
If you printer is USB you should shut down your computer. Next turn off your printer. Unplug the USB cord of the printer. Boot the computer. Turn on the printer power. Plug in the printer USB cord. The computer should find the printer and load the driver. Go to control panel and look for printers. Find your printer. Right click your mouse on your printer and set it as default printer. Now it should work when you try to print to it.
Mar 05, 2011 | Office Equipment & Supplies
Will not print, is their cord that plugs into the computer. I have the power on
Hi
Please check that the usb cable from the Printer to your system, If yes then check the printer is correctly installed in your system by clicking the start, Control panel, printers if no then install the printer by using the printer CD. This will solve your problem
T.Boopathy
Aug 17, 2008 | Lexmark Office Equipment & Supplies
19 people viewed this question
k24674
Marvin
Marvin
