Question about Cnet CSH-800 8-Port Ethernet Switch
Cnet CSH-800 8-Port Ethernet Switch no power - Cnet CSH-800 8-Port Ethernet Switch
  • Cnet Master
  • 32,281 Answers
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
Posted on Dec 11, 2009
How do i configure the CNET 16ports switch to allow or not web access through?
Unless I'm missing something, you can't. This is a basic switch with no advanced application aware features.
May 02, 2015 | Cnet CSH-1600E 16-port 10/100Mbps Fast...
How to reset the switch CNET CSH-1600
No manual. Maybe a pinhole reset switch?
Mar 28, 2014 | Cnet (CSH-1600) (CSH1600)
Pleased i need to download the remote management software (rmt) for cnet csh 2400 switch. where can i do this
Don't know about a special program, but you can try to use Centrastage (www.centrastage.com)
It's a remote management software and it seems like it can be useful for you.
Jun 29, 2011 | Cnet CSH-2400 (csh2400) 24x10/100 Mbps...
CSH-800 8-Port Ethernet Switch Problem When i switch the power on, only the POWER LED light up and nothing is happened, computers cant detect it
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
May 10, 2011 | Cnet CSH-800 8-Port Ethernet Switch
How do i disable dhcp in a cnet 8 port switch?
Hi!
I should mention that network switches don't have any ability to assign IP addresses. In other words, they can't act as DHCP servers - therefore there's nothing to disable!
If your network has a router (or a modem-router), configurations should be made in it...
BTW, you can disable DHCP in Windows (i.e. assigning a fixed IP address to each computer on the network) but following this (the part that should interest you has the title "If Your Router Doesn't Let You Set Static Local IPs").
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Dec 08, 2010 | Cnet CSH-800 8-Port Ethernet Switch
Which type of cat-5 cable do i use to connect a cnet switch to a d-link switch
interConnecting two switches will need a crossover cable. Please use a crossover cable.
Oct 27, 2010 | Cnet CSH-800 8-Port Ethernet Switch
Switch CNET CSH-2402G PASSWORD RECOVERY
it should be 4 digit 1234 if still doesn't work you may try reset
Good Luck
Jun 16, 2009 | Cnet CSH-2402G
Don't have internet connection
This particular 8-port Ethernet switch/hub has auto-negotiation on both speed as well as MDI, MDI-X.  Therefore, the problem is not with your switch/hub, it's probably with the particular port that you're connecting it to on your Router.  Make sure that it's the LAN side, not the WAN side.
Mar 14, 2009 | Cnet CSH-800 8-Port Ethernet Switch
CNET CSH 2400 24 PORT SWITCH - LINKING TWO UNITS
You might be having problem in following area 1. Check the cable first. You can use the cabe tester. If cale tester is not available then chek the cable with multimeter. 2. Check the port wher you have inserted the patch cord. It should be in uplink port of first hub and normal port of second hub. Try this and revert back with results.
Feb 08, 2007 | Cnet CSH-2400 24-Port Ethernet Switch
Cnet CSH-800 8-Port Ethernet Switch Logo
309 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
ddalecki
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
