Question about T-Mobile Sidekick® 3 Cellular Phone
Ive already tried two different people for a unlock code for a sidekick slide locked to t mobile and they said they cant do anything. can you guys?
Need a code to unlock a sidekick slide
hi if you are in need to unlock your sidekick mobile from network lock then codes are the simplest way to unlock it .to get codes visit prounlocking.com here they provide codes for all gsm mobile models.
Jul 25, 2012 | T-Mobile Sidekick
Unlock code
I will help to unlock the SIDEKICK SLIDE from United States T-Mobile Network lock,Get the Unlock code for SIDEKICK SLIDE from here Classicunlocking.com/sidekick-slide/rs17wp9/ and unlock it.
Nov 27, 2011 | Motorola Cell Phones
My sim card is locked on my sidekick slide and i cant unlock it..
If it locked to network means You can get the Unlock code from here Unlocking4u.com and Unlock it....it locked to security code means get the code from service provider and Unlock it...
Aug 12, 2011 | T-Mobile Sidekick® 3 Cellular Phone
I have a sidekick slide that i tryed to unlock so my at&t sim card would work in it well i watched a video off you tube and now im locked off phone and need HELP! asap so i have phone for work please...
Find which Network locked now,get the code from here
Theunlockarena.com and Unlock it,Check code for Your Network Lock,Follow the instructions below and Unlock it step by step./...Instead of watching video ,you can use the safe Unlock code method using instructions Unlock it step by step...
Sidekick SLIDE Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Sidekick SLIDE mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick SLIDE mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick SLIDE with a Not ACCEPTED SIM Card.
2. If your Sidekick SLIDE asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick SLIDE will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick SLIDE is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick SLIDE is locked to.
Jun 18, 2011 | Cell Phones
I cant unlock my sidekick. its asking m for a privacy lock. how can i get it?
If you want to unlock your mobile so that you can use with different networks, you can get the codes from www.mobile-unlocker.com.
Oct 04, 2010 | T-Mobile Sidekick
Cant get my sidekick to activate
Let me start by saying I'm not an expert, but after going through a lot of gyrations I came up with a solution that worked for me. I'm sharing it here because I haven't seen a complete concise answer anywhere.
The activation problem with Sidekick Slides is common. Most of the time, people buy a Slide without realizing that you have to purchase a "sidekick plan" from T-Mobile to get it fully activated. These phones were build especially for T-Mobile, so they're designed so that you have to have a Sidekick rate plan first to get the phone activated. By the way, this applies to a new phone as well as a phone that's been activated before, but has been 'hard reset" (where you hold the R button while re-booting.. My advice, DON'T DO THIS! Because you have to re-activate the phone.
However, there's good news for all you non-T-mobile folks who bought a Slide on eBay (or from a friend etc.) only to find it needs activation. Here's the solution. If you search eBay for "sidekick activation" you can find folks selling prepaid activation kits for around $15. They include a sim card and about $10 worth of sidekick prepaid services. Buy the kit, install the sim, and go online to register your phone (registering by phone is a pain with T-Mobile). Online you have 3 plan choices: Pay By The Day, Pay As You Go, and Sidekick. Pick Sidekick, and then provide the requested registration information. When done, your phone should be ready to go and should activate within about 5 - 10 minutes. You'll be charged $1 a day and airtime for calls, so it's not cheap, but at least the phone won't go to the activation screen when you startup.
The next question is, how to unlock the phone for other networks? IF it's not unlocked you will be prompted for special code (this is different than the user-defined password that simply locks the phone against unauthorized users). It won't work on other networks until it's truly unlocked. Again, the trusty folks at eBay can help. I searched for Sidekick Slide Unlock Codes and found numerous vendors, ranging from $6 to $12, who provide permanent unlock codes for Slides. I found on that provides the code via email (others want to mail it to you) and got my code within 30 minutes. So now I can remove the T-mobile sim and put my ATT (or other) sim in and go. I should mention that some of the Sidekick features ONLY work if you have a sidekick plan, but that's T-Mobile's and Danger's devious attempt to make us miserable. Good Luck! Hope this helps! Rick
Sep 13, 2009 | T-Mobile Sidekick ID Cellular Phone
I have a t mobile sidekick and and i have at&t chip how can i unlock the sidekick
you will need to get a UNLOCKED sidekick. otherwise, you cant.
[that is if you got a sidekick that is restricted with tmobile network only]
however, there is actually have some unlock code that can able
to un-locked it but you wont be able to use anything on it
especially only make a phone call and use txt and thats basic it.
unlock code thing can be found on ebay.
Jul 25, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick slide-urgent help, please.
i have a T-Mobile Motorola Sidekick Slide and i would love to get it unlock but i dont know the code so please i'm asking for your help to unlock it for me , Thank you.
Mar 10, 2009 | T-Mobile Sidekick II
Currently i have a cingular phone and bought a t mobile sidekick slide hoping you guys can help me and get an unlock code for my sim card..
you need to unlock ur sim or the phone? the phone needs a puk code. i have that. its not free though. email me
Jan 28, 2009 | T-Mobile Sidekick II
I locked my sidekickslide with the 3 digit code how do i unlock i
Call T-Mobile and have them reset the code for you. Or try to remember the code you used.
Jan 11, 2009 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
27 people viewed this question
Top T-Mobile Cell Phones Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
