Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
Bios i want to ecover te bios
  • Anonymous Feb 14, 2008
    i removed the CMOS battery for 5 minnutes and after putting it back my BIOS settings were gone, now every time i boot i have to press F1 to continue. pls help
Every time i boot i must press F1 to continue. and when i want to shootdown it doesn't automaticaly, but appear the note "now save to turn off .......etc pls help
Posted on May 09, 2008
  • abbah jawara May 10, 2008
    my intel mainboard socket 478 get trouble when i want to shootdown it doesn't automaticaly, but appear the note "now save to turn off .......etc pls help
Get a new battery cymos
Posted on Mar 03, 2008
You stuped forengers! are you marsianing?
Posted on Feb 29, 2008
  • 40 Answers
6ya staff
SOURCE:
Why does my keyboard did not detect on G31 M7 TE
Try using a PS2 keyboard or a USB keyboard with USB-PS2 adapter.
USB port may be disabled at BIOS.
Jun 27, 2014 | Biostar G31M7 TE (INTEL G31 MOTHERBOARD ...
Aspire acer 5100-3959 notebook bios password
step 1. try entering bios setup and get the error code for example 23456
step 2. in other machine use hirens boot cd and open bios password generator
step 3.- choose te option 2 and put your error code.
it works for me on acer 2920 whit phoenix bios.
Jul 26, 2012 | Acer Aspire 5100 Notebook
En la parte superior izquierda de la pantalla aparece un candado , aparentemente pide una contrasena o algo asi , como puedo desbloquearlo?? gracias
hola,
Antes de nada, prueba a usar las contraseñas maestras para la bios de ordenadores IBM:
IBM IBM
MBIUO
merlin
sertafu
Prueba cada una de ellas por separado. Si ninguna de estas opciones te funciona, la única opción es realizar el minicircuito descrito en esata página web:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Aunque retires la batería CMOS del potátil, la contraseña de BIOS no se reseteará. La única forma de resetear la contraseña, es realizando el tutorial que antes te he mostrado.
Feb 25, 2011 | Lenovo ThinkPad R61 Notebook
How to update bios on g31-m7 te motherboard
Go here -
http://www.biostar.com.tw/app/en/mb/bios.php?S_ID=363
D/L the file and install..simple..Just dont touch anything while its installing as it might not boot again.
Dec 29, 2010 | Biostar G31-M7 TE Motherboard
Muchas gracias por la oportunidad, es una Toshiba Satellite 5005-S504 de minguna manera entra a la Bios, Qué puedo hacer?
si puedes leer ingles este sitio te servira mucho. te dice como resetear el BIOS. y sitienes una password como resetearla en tu toshiba.
http://www.tech-faq.com/reset-bios-password.html
espero haberte ayudado en algo.
Dec 09, 2010 | Toshiba Satellite 5005-S504 Notebook
Reprogramar bios
Aquí te envio el enlace para que descargues el Bios hay varias versiones, controladores y manuales. Te recomiendo que seas cuidadoso con el Bios ya que si descargas este y lo aplicas incorrectamente sucede lo que se llama flashear el Bios y tu procesador quedaria inservible. si lo has hecho antes y te sientes confidente adelante.
si esto te funciona no olvides calificarme grcs
Here is the link to the page where you can download the Bios (there is a few versions), drivers and manuals. I recommend you to be careful because if you apply this changes to the Bios incorrectly can happen what is called Bios flash and that will ruin your processor. if you have done it before and you are confident then use the link.
if it works for you, don't forget to rate me
thx
May 26, 2010 | EliteGroup ECS G733 Notebook
NO SE PUEDE INICIAR EL CARGADO DEL PROGRAMAS PORQUE TE PIDE PASSW
Remueva la bateria recargable, la bateria del BIOS y el power cable por 10 minutos. Esto borra el password del BIOS. Re-instale todo y trate de nuevo
Mar 11, 2010 | MPC Computers TransPort X1000 Notebook
How to reset bios password for g31-m7 te
Case1-if system is working than run cmos.exe
(download from internet)
Case2- if system is not booting than reset system jumper.
Nov 18, 2009 | Biostar G31-M7 TE Motherboard
Urgente¡¡¡¡¡¡¡¡¡¡bios de mother m748lmrt
QUE NUMERO DE BIOS TIENES EN ESTE MOMENTO
ESA INFO ES LA MAS IMPORTANTE PARA PODER AYUDARTE
DEBES FIJARTE EN EL NUMERO DE PC BOARD
(ES UNA ETIQUTE QUE DICE : VER:XX)
Y AL INICIAR, TE METES EN LA BIOS Y TE FIJAS QUE VERSION ES LA QUE TU TARJETA LLEVA.
Jul 19, 2008 | Intel Motherboard
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
110 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
