Question about AT&T Quickfire Cell Phone
My screen went all scrambly the other day and it will not go back to normal it turns on just all scrambled
Scrambled screen
could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
Aug 31, 2014 | Dell OptiPlex GX620 PC Desktop
Scrambled laptop screen
Scrambled is a subjective term that is useless in trouble shooting.
Sounds like a virus.
Mar 31, 2014 | HP Computers & Internet
LG 8300 phone the display screen is distorted / scrambled
The problem with your phone is that the flex on your phone screen is malfunctioning, that is why the screen is distorted.
All you will need to do is to change the flex on your phone screen because it is now faulty.
Change the flex of your phone screen as advice and you will see that your phone screen will be back to normal.
Take care.
May 03, 2010 | LG VX8300 Cellular Phone
The view on the screen get scrambled , cant see anything on the screen. However, after a while it went back to normal but then it get scrambled again. The problem occurs randomly sometimes the computer can...
the problem related to video card, if you using on board try to add video card and install driver. of course clean also your memory card pin by using an eraser pad.
Mar 25, 2010 | Computers & Internet
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
Mar 21, 2010 | HP LCD Display for Compaq Presario R4000
The screen is scrambled at times. It seemed like
it's probably not the LCD, it is most likely the ribbon cable... it could be repaired or if not, replaced...
Nov 08, 2009 | HP Pavilion dv9720us Notebook
Samsung HLP5063W 51 inch DLP is 4 years old. Screen scrambled?
there is a complete section in the tv that translate the different resolutions from the different out side video sources you normally use to the TV native resolution. That area has to be replaced. Is a module repair needed. Don't get scare. now days this kind of repair is normal and has to be included in the repair price to see if is economical to repair.
Mar 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Scrambled screen
Well, whatever the cause, it would seem to be software related. If you cannot boot into an earlier restore point, try booting from an XP disk. May have to do a repair on the O.S.
Also, just for fun, connect an external monitor and see if it has a screen.
Good luck
Dec 14, 2007 | Dell Inspiron 6400 Notebook
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
AT&T Quickfire Cell Phone Logo
214 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
