Question about Syntax SV266M Motherboard
Video black with 7600gs card installed
I have the Syntax sv266m motherboard. i have 1.5gb ram and a 600w power supply w a athlon xp2000 cpu. i put in a geforce 7600gs WITH the power pluged into it and get the black screen. Machine and card fan is running, just black screen. agp video option is on as well to display agp video 1st. card is good just must be incompatible i guess. what is the fastest most mb agp card i can use with this board if no one knows how to get this one working?
  • 6 more comments
  • bandit11 Dec 11, 2009
    yes i am 100% sure. im not that stupid lol. its a xfx model PVT73KUAL3
    the card works in other systems but not this one and other cards work in this system in agp. weird. i seen others having this problem around the net but no one has a fix :( im willing to buy a new card if needed just want the fastest for this system as it is used for a mame system :)
    GUYS THIS IS A AGP CARD NOT A pci-e
    THIS IS A xfx 7600gs AGP card. so i have no idea where you got that i shoved a pci-e card in the slot. dont assume
    SOLUTION #1 needs to be deleted due to it pertainning to a pci-e card which this is NOT.
    sorry byteguy.. i know you didnt assume.. meant the expert that replied. :) hope you can help
  • Art Ellison
    Art Ellison May 11, 2010
    Oh, sorry 'bout that!
  • Art Ellison
    Apparently you aren't as sure as you thought you were!
  • Art Ellison
    You sure it's an AGP card and not a PCI-E?
  • 728 Answers
Hi bandit11,
First how did you get a PCI-Express X16 like the 7600 onto a AGP 4X port?? Two different animals. To answer your qustion, no that Card will not work on that Board. You can spend your money if you want to on some of the higher speed video cards but, to be turthful, I wouldn't. The CPU and memory will limit any of the newer cards that will fit that board today. But, if you really want to keep that board, then I might suggest to look for a $40-50 Radeon 9700 pro or 9800 pro. Anything more than that is a waste of your money.
Bottom line a lower end AGP cardwon't give you any more card performance then high end AGP card if you must upgrade, go used and cheap...nothing fancy.
Best of Luck
Mark
Posted on Dec 11, 2009
  • Mark Taylor
    Mark Taylor Dec 11, 2009
    Hey Dude,
    It would of been nice if you would of mentioned it was a PVT73KUAL3. If you care for FREE help, I'd be a little more descriptive in your questions. In regards to your problem have you updated your boards bios. Your putting that type of card, (which by the way the board is not supported according to nVidia) But, on a board that should work, unless your drivers for the board or power supply isn't up to speed. Which with a 600w PSU you shouldn't have any problem. Also I don't know if you have the driver that nVidia put on in 2006 that allows it to work with XP, Vista. You can get it HERE.
    And I still stick to my original advice that regardless of what you put on that board, it's not going to preform as you want.
    Later,
    Mark
Asus m4n78 pro no starting problem
check out power supply then cpu fan is running and video card works and ram is in all the way make sure that all the power plugs are in the right places as well on the board
Mar 15, 2013 | ASUS M4N78 PRO Motherboard & AMD Athlon II...
No video onboard, se provó
Hice downgrade a la bios por la versión nM916.bin (buscala en driversguide como: SV266M_RealTek.zip) y NO! SV266M_ICS.zip porque luego de flashear no arranca mas.
Dec 15, 2010 | Syntax SV266M Motherboard
The motherboard is an A785GM-AD3 Black. I just built this system and I can't get a display or post out of it. I noticed that a red standby light is solid the entire time power is to it. Please help me. I...
1. Check power cables (It goes standby mode when there is not enough power supply)
2. Check CPU seating and CPU Power socket
in some cases CPU socket(on the MB) may be damaged
3. check the RAM (if one of the RAM malfunctioning)
4. Clear the CMOS/BIOS battery (b4 disconnect main Power supply)
5. CPU Power FAN / Heatsink. If not proper, 4sec system go standby down.
6. Do u correctly connected 12vATX to CPU
I hope This will solve your problem. If not may be need to replace your board.
Sep 17, 2010 | EliteGroup ECS A785GMAD3(V10) Socket AM3...
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
Drivers needed for syntax sv266m motherboard
You can try following links for downloading the drivers:
http://download.driverguide.com/driver/SV266M/Syntax/d350111.html
http://ar-domena.com.pl/sv266m/
Nov 04, 2009 | Computers & Internet
Computer starts but does not post Athlon XP KM4M DDR
if the system made no beeps after the machine was booted with no ram its a bad board...sorry
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Aug 10, 2009 | Computers & Internet
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Syntax sv266m motherboard....it wont go past the windows xp scree
check if the safe mode is working..?pressing F8 just b4 windows xp screen comes up...
if yes then good...
check if u seated the ram properly?.and check if its showing the full amount of ram in the bios page..
Mar 04, 2009 | Syntax SV266M Motherboard
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
Syntax SV266M Motherboard Logo
142 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Mark Gough
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
